Thread: Speaker Help!!
Showing results 1 to 12 of 12
    Rob Yung
    Speaker Help!!
    Ok I Got A 8g And Just Installed My Sound System... The Sound System Is Great But When I Turn It Up Loud The Bass On The Factory Speakers Are Too Loud Like The Bass On Them.. So I Turn Just The Bass Down But Then The Bass On My System Goes Down So U Can Barely Hear It...
    Is There A Way I Can Take Just The Bass Off The Speakers On The Inside Of My Car Or No?
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    yes, it's called a high pass filter aka bass blockers
    Rob Yung
    ok and how do i do that... lol im not a tec wiz.. sorry if i sound stupid
    01-10-2008
    1,848
    connects to your speaker wires
    Rob Yung
    ok cool.. but theres no way i can do it from the radio and adjust them.. cause man the bass hits hard in the car and i can't hear the systems bass
    01-10-2008
    1,848
    yeah, turn your bass all the way off on your HU. that's the only way. do you have subs in your trunk? could also adjust the fade
    id do bass blockers they are like 12 bucks for a pair.
    Rob Yung
    i tried it... but the bass goes down on the subs too!!
    08-04-2004
    Westchester NY
    1,332
    what exactly do you consider a sound system, what did you have installed?
    sound system to me doesent = stock speakers
    did you do a sub and amp, on factory deck,
    amp sub on after market deck? or what.///
    01-10-2008
    1,848
    Quote Originally Posted by Rob Yung View Post
    then you need bass blockers
    Rob Yung
    nvm.... i got it!! thanks for ur help fliegendaffe
    I would probably install something in the order of blocking anything below 100 hz. Then set the low pass for your subs to that point, probably lower.
    sig too big
