Thread: STP Fuel Injector cleaner and STP Gas treatment
Showing results 1 to 17 of 17
    TGC Regular Gladiator's Avatar
    03-19-2003
    Rego Park Queens
    443
    any experience with the above two treatments?
    Thinking of mixing some in w/ my next fill up and oil change.
    07-19-2007
    Connecticut
    3,994
    i thought it helped, but only 1 tank. it was worthless after the first tank. im getting a full tune up instead because at 103k and i bought it at 93k im sure it was never done.
    09-10-2003
    Charlotte, NC
    4,463
    butt dyno products, doesn't do much but you can add it to feel better about yourself, i used to
    08-15-2006
    Perth Amboy, NJ
    1,558
    i agree with 99, it only worked for one tank with me
    run1206's Rear Disc Tutorial
    I'm not a believer on this stuff removing deposits and at the very least it improves the quality of the gas/to not contribute towards making deposits and maintaining the quality of the gas and removing some water in the fuel system. If anyone has cleaned the intake/exhaust valves of a engine with a decent amount of miles would understand; you quickly learn the dremel is your friend and some good carb spray takes the deposits off with some thorough dremeling; so I can't see a liquid diluted in 13+ gal. of fuel anywhere near making a difference in removing anything in the fuel system thats hampering making your car run rough..etc.
    08-04-2003
    NY
    4,344
    the only fuel injector cleaning product I ever had success with was the one from Lucas. My fiance's civic had a noisy injector and after one use of the lucas fuel treatment no more noisy injector. The injector was noisy for about 3 weeks, then 2 days after adding the lucas, it was gone.
    99' Galant ES
    4G64/63T
    AEM EMS
    07-20-2003
    Orlando, FL
    3,169
    I agree with Stewi...Lucas products are great. I worked in the automotive industry for 8 year and have heard alot of things about fluid additives out there in the market.
    For fuel I would use Lucas, BG, and Chevron "Techron" and Sea Foam additives
    For oil I would use Lucas, BG, Marvel Mystery oil.
    I have been using them but I think it doesnt have a great of affect like everyone wants to think. sure it would help clean deposts and reduce water in the lines for faster starts but it wont reduce the wear of the parts and wont help have greater gas mileage....
    08-06-2005
    Long beach/ guam
    1,585
    well don't really care if it works or not.. most of the gas was said to already have cleaning additives, but i still put stp injector cleaner every full tank.. doesn't hurt to try...
    stkiflngaz
    yea your supposed to use with every fill up so plan on buying a lot of them...
    Banned
    12-12-2009
    https://t.me/pump_upp
    154
    Seafoam
    I use lucus and it does work, cleans the injectors well, i had a little bit of an idle problem, little more rough than usual but i had done wires and plugs about 5,000k agao so i just used lucus and it smoothed right out.
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    In my experience, Lucas works the best. I have used STP and others before and I didn't notice an improvement.
    10-05-2008
    Grand Rapids Michigan
    1,141
    Yeah the first time i used Fuel Injector Cleaner the STP stuff it was not bad, but then it was just a waste of money after that like many others have said
    ISMASG90
    You should try BG products, 44k is a gas treatment. I used the kit to clean the fuel system.
    what is that cleaner bro?
    can you share it?
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    ^ Brand named Lucas :) u'll find it almost in any automotive place (autozone, pepboys etc..)
    ________________________________________
    -RON
