Thread: Air ride kit
Showing results 1 to 5 of 5
    Galant01
    Air ride kit
    Would an air ride kit for an Accord work for my Galant? If the weight is close but I know that I would have to get new brakets.
    Galant01
    does anyone know???
    TwistedGTZ01
    well, i've been on air ride for almost 2 years and i have no clue. when i ordered the kit, i had to make sure they knew exactly what car i had. most likely, it was for the brackets and such. i don't think the weight of the car has much to do with what bags to actually use. i think its the strut inside the bag. unless you have someone practically paying you to take this kit, i would just get a kit. they only run about 1600 bucks with everything you need. install is easy. i don't think its worth the custom hack job to get an accord kit to fit. but in response to your question.....if you made every bracket new, fit perfect for the galant, i would say the accord bags would work fine.
    Galant01
    where did you get yours?
    Galant01
    Also, I was looking at your pics. And where is the tank?
    Ps. car looks damn good
