Thread: 7G: DIY Rear Drum-to-Disc Brake Swap
Showing results 1 to 18 of 18
    12-17-2002
    Sherman Oaks, California
    4,304
    http://socallifestyle.com/rear_disc_.../tutorial.html
    all questions/comments welcome...fire away
    [email protected]
    02/17/2009 - UPDATED!!!!! UPDATED---------
    the tutorial has had information added regarding the necessary transfer of the 2G prop valve. this is an imperative addition!!
    1994 Galant GS 5spd
    holy shit its Peano
    Experienced TGC Member rez887's Avatar
    06-10-2005
    Dallas
    1,236
    Welcome back Peano!
    Quote Originally Posted by QnzMostWanted View Post
    holy shit its Peano
    Why you keep posting on TGC!!!!
    joking haha
    Experienced TGC Member Bezzle's Avatar
    11-12-2005
    Paterson TGCNJ
    1,940
    O shit its Peano and Denver! Great write-up as always.
    Peano Great tutorial!!! Going to think about doing this one this summer.
    1996 galant s
    Good to see you back Matt and another great writeup like usual.
    222whp/250wtq
    TGC Regular phizzalot's Avatar
    04-25-2007
    Orlando/Ft. Luderdale ex {phizz2k}
    727
    Nice to see you posting up again man :) Your tutorials always makes things seem so easy, thats why I did the 5speed swap.
    What was the most difficult part ( 5speed swap = throwout bearing.) Anything like that, with this?
    12-17-2002
    4,304
    adjusting the e-brake to spec, simply because it's a lot of guess work. the manual says to open the adjuster enough to lock up the rear wheels, then go 3 clicks back. it says to spin it with a screwdriver through the hole in the "drum" part of the rear rotors. much easier said than done.....
    1994 Galant GS 5spd
    great write up. came in handy when i did my swap a few days ago
    Quote Originally Posted by polishmafia
    You want real respect from those fools? Don't race him. Tell him racing is a sport left to young boys who are still waiting for their balls to drop. Then while he's out racing, fuck his girlfriend in the ass, take pics, and leave them on his car while hes at school.
    Unless your frequently stopping from 150mph to like 45 mph (actual racing conditions) you do not need those drilled and slotted rotors, standard vented rotors will be just fine for you. The superior cooling of those rotors is designed for those extreme heat conditions to keep them under 600 degrees. Trying to stop with them from 45 mph can be a bitch becuase they don't heat up fast enough for the proper friction. Also, the rear brakes only do about 10 percent of your braking, which is why they used to just use drums becuase its more cost effective, and its a better parking brake, evidenced furthermore by the fact that even rear disc brake systems have internal drums for the parking brake.
    141,000 miles.
    6 dents.
    Yellowed, cloudy headlights.
    spraypaint on the door panels.
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    the only advantage of rear disk brakes, is that they cool off better than drum brakes, and you have choise of different pads
    Build Thread
    not just that, but they perform the same under all conditions. once drums heat up after a couple stops they don't brake hard.
    also i have no abs, so even when my fronts lock the backs still stop the car, and they work better than the drums
    Peano,
    Great write up. What model/year are those brake parts and rotors from?
    12-17-2002
    4,304
    rotors are for 7G. all e-brake parts cross referenced from a GS
    1994 Galant GS 5spd
  15. #15
    12-17-2002
    4,304
    ---UPDATED---
    per the new proportioning valve discovery made in this thread:
    https://www.thegalantcenter.org/showthread.php?t=30410
    the tutorial has been upaded with a brief explanation on transfering over the 2G prop valve. this is a safety concern, and i strongly insist you perform this transplant before driving!
    1994 Galant GS 5spd
  16. #16
  17. #17
    09-20-2007
    Sea Isle city, NJ
    4,098
    Good shit. Glad I was able to help.
    Where did you get the rotors from? Just to have some more info for other members who want to stay with 4 hug pattern
    Build Thread
  18. #18
    i got them from ebay. they are of cquence brand. i looked them up read some good things about them. after u buy u specify the style u want and after that its 2 weeks for them to make them. they look good. install was very easy. i made the hole for the ebrake on the back of the backing plate bigger with a drill becouse it needs to be just a little bigger for the cable to fit correctly. now for the lines i looked locally on almost every auto parts i could find and no luck. i ended up buying some for a montero front lol
