Buy an EVO... JK
What are all the things you can get to add HP to a A/T(other then turbo). I know some of the main ones, but there has to be more.
SRI or CAI
Catback Exhaust
Headers
intake manifold
2000 Galant ES 2.4L
I would if i had money! I dont have enough money to put turbo either. Im 16 working at McDonalds so i got a low budgets thats why im working on hp gains that are $300 and lower every two weeks. Im gettin the outlander intake manifold swapped by the end of this week and i dont have to pay so i got money this week and dont know what to get.
2000 Galant ES 2.4L
i got an SRI and a muffler
2000 Galant ES 2.4L
suspension could help with handling, price varies though
run1206's Rear Disc Tutorial
i might be wrong but the outlander intake manifold doesn't give you HP its just stronger than we have now "i4".please correct me if im wrong.
save the $300 every two weeks and get some turbo. headers will cost you around $400,$250 for a good CAI and $400 for the catback. if you save those money instead your half way there to buy turbo :)
TURBO= in the making.......
Those are all good basic bolt ons, I had a custom intake manifold built.
is that it? i know theres gotta be more stuff that adds hp other then the stuff i listed. i got 99000 miles on my car and idk if its worth it to go turbo. if i do what are some things i can buy now and have installed to get ready for turbo but still drive my car daily???
also ive been reading the turbo section and im not getting it. I probably wont be able to intsall myself and i dnt know where to start with parts or where to get them.
2000 Galant ES 2.4L
reduce as much wieght as you can, wont increase hp but or every 500lbs you drop you lose a .10 second off your 1/4 mi
cf hood and trunk
took me a few months to research my stuff before my install; i'm still researching the mapping for the fuel and timing in ECUFlash.
mtcavity put a turbo on his G at over 100,000 miles. seth is well over 230k miles and is still going strong. i'm sure you can do it, just search for your parts. and read some of the turbo build threads here, i know on mine is a FULL list of parts to get.
^^ true, make sure you save up money to get good quality parts, that way you don't spend alot on replacement parts from them breaking down.
Good job ... way to forget about me ... turboed at 185,000 now boosting 12psi at 199,000. All original internals. ;)
222whp/250wtq
Im at 219k and about to throw my turbo parts on.
THeres not much more you can do other then replacing the entire stock exhaust with a header and free flowing exhaust and getting into the engine. Could do a port and polish on the head, oversized valves, valve springs and retainers, cam, adj cam gear, have a custom SMIM built, and more. But all that will cost you some money, especially if you dont do it yourself.
