This is the oil that you can use, buy it yourself and take it to the shop that will perform the flush, save you some cash. You need about 5 to 6 quarts. You can buy this oil at Auto zone and is equivalent to the one the dealer uses.
I've been reading the threads about transmission fluid and being one of the problems with not smooth shifting of gears in an Automatic transmission. I'm planning to get it flushed and refilled with the recommended Diamond SP-III fluid that was mentioned. My question is, do I go to the dealer to do this, or can I do it at any other auto shop? In one of the threads I did notice that there are a few members that live in the Maryland area, can anyone suggest a good place that knows Galants? Mine's a 8g 03 model. I read in one thread that you can get the fluid at Rockville Mitsubishi for a reasonable price. How much should I buy? 11-12 quarts? I don't like the guys that I met at the Rockville dealer as they were so unresponsive to my questions. I also read on another forum that Hillmuth Automotive is good, I did take my car there for some minor work which was rather expensive, so that's why I need recommendations please.
how many miles u have if under 60000 come to va ill flush it for u
I always used the mitsu fluid and its not that expensive. I think 5 quarts was like $23. You can just walk in to the part dept. at your local dealer and buy it.
4G64/63T
AEM EMS
Diamond SP-III fluid is the same thing as the castrol... read the back for specific types
Be careful flushing it above 75,000 miles, it can be more detrimental to the transmission.
Yeah, I read about that too, about the stuff that comes out might actually damage the transmission filter. But I think the previous owner had changed the fluid, but may have not used the right one... I get a weird issue, when I'm between 60-70mph, and the RPM is about 3000-3500, I notice that the transmission slips a bit bringing the RPM to about 2900 and then goes back up again. Also with the A/C, the transmission doesn't shift that smoothly at low speeds. Just thought of giving the transmission fluid a change and then checking out for further issues. Any ideas?
run1206's Rear Disc Tutorial
at my dealer they charge 13 dollars found another dealer charges me 5.75 bucks i just gotta drive like 3 miles extra the oppisate way
03 I4
