Thread: sway bars - do they exist?
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 41
    12-17-2002
    Sherman Oaks, California
    4,304
    do they make sway bars for 7G galants? if they do, where can i get my hands on one? and if they dont, is it possible to use an eclipse sway bar or something mitsu related?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    12-17-2002
    4,304
    ahhhh i just wanna know, are they out there??????? someone reply!
    1994 Galant GS 5spd
    San Antonio, Tex-Mex
    1,413
    You mean a rear sway bar right?
    OBX makes them for the 7g, it's like $100. Check here... Clickity Click
    <-Check it out Maz
    My 7g
    BEAST
    Is it worth the $100? Will it make that much difference in handling?
    Dark Anghell
    I think you mean the bars that go under the car...If that's so then they do exist. They go for 280 bucks and include some of the bushings.
    Oh and 280 is for front and back. The company also makes complete bushing kit for our cars. That thing goes for about 300 I think.
    Company is called White Line or something like that. I have to find the url...it's written somewere in my notebook
    your galant already has sway bars.
    only GS, and LS of some years came with a rear sway-bar
    otherwise, you have just a front (which is Exacty the same as the FWD turbo 2g)
    if you want the rear, you can just snatch-up the parts From a 94 GS, or Try your luck in CAPS.
    every time I went into CAPS to loo up the parts, I got "no data" for the Rear #'s =0[
    unless Someone has a GS VIN?
    Craig R.
    1996Galant 14.0@103
    biggest b00bies EvAr
    I have an upper strut tower bar, that helped a lot when cornering. But the back had some understear.
    Then I got the rear lower tie bar and that helped out a lot with the understear problem.
    My car now has awesome handeling.
    I spent less then $75 for both bars. Definitely one of the most bangs for your $.
    do these fit? i forget...i think the FSTB will fit but i was wondering about the rear. anybody know?
    BEAST
    <div class='quotetop'>QUOTE(Jesse)</div><div class='quotemain'>I have an upper strut tower bar, that helped a lot when cornering. Â*But the back had some understear.
    I spent less then $75 for both bars. Â*Definitely one of the most bangs for your $.</div>
    Where did you get them?
    1,413
    <div class='quotetop'>QUOTE(seth)</div><div class='quotemain'>do these fit? Â*i forget...i think the FSTB will fit but i was wondering about the rear. Â*anybody know?</div>
    Almost certain it will Seth.
    BEAST, according to OBX.. any lower tie bar for the 95-99 Eclipse and 90-97 Accord will also fit the 7g. Look for those as you can find them waaaay cheaper.
    <-Check it out Maz
    My 7g
    12-17-2002
    4,304
    aight, well then i got a real question
    http://www.obxracingsports.com/performance...D=3&subcatID=17
    whats the difference between that ^
    and this:
    http://www.obxracingsports.com/performance...=17&subCat2ID=2
    whats with the price difference? and the way they look is diff. too.
    1994 Galant GS 5spd
    1,413
    If you want the model with "speed holes" it will run ya $20 extra...
    The $79 one will get the job done just as well.
    Actually a 1.5" pipe flattened on both ends will work also
    <-Check it out Maz
    My 7g
    id drill my own holes for $20 :lauging:
    BEAST
    Ok so where exactly do these things go? Under the car or behind the back seat. I think I remember seeing a galant with a bar behind his back seat. Like if you fold down your seat, the two clips the back of the seat hooks onto. Or does this actually go on the outside under the car?
    1,413
    These go on the underside, literally between your rear suspension. The one you're thinking of is a RSTB that connects the rear strut towers, works just like the front one evryone has.
    <-Check it out Maz
    My 7g
    BEAST
    I might just have to invest in one once I get some more dough.
    12-17-2002
    4,304
    damn, i was somewhat convinced to get one, but now i have to get one, all this good feedback on these damn things. i found a 95-99 eclipse rear lower strut bar on ebay for 45, and s/h is at 12. so it's a lot better than the obx website. just lettin everyone know
    1994 Galant GS 5spd
    so is there any out right now that fit the rear upper back part of the galant? and what other things can be purchased to improve handling besides strut bars?
    Any 2g strut bar will work. Upper or lower. Suspension bushing kit for the 2g would greatly increase the handling. Just a pain to install.
