Thread: Busy weekend ahead...
Showing results 1 to 5 of 5
    Cam shaft seals 2 x 2.64
    Main seal 1 x 3.05
    Timing Belt kit x 52.45
    Timing belt tensioner 1 x 74.26
    HLA’s 24 x 4.95
    Valve cover gasket set 1x 17.05
    Intake chamber gasket 1 x 3.91
    Wires 1 x 42.80
    Plug 6 x 2.32
    Cap 1 x 22.91
    Rotor 1 x 14.53
    Idler Pulley 1x 66.35
    Front Strut 2 x 47.82
    Rear shock 2 x 57.46
    Front Sway bar links 2 x 17.66
    Rear swaybar link 1 x 14.38
    KYB left rear kit 1x 10.43
    Kyb right rear kit 1 x 10.43
    Flush Power steering rack
    Change engine oil
    Flush transmission.
    Lots of work..... gotta keep the wife happy :)
    [email protected] <- '01 ES V6 (detuned for daily commutes)
    Black '94 Audi S4 soon RS2'd running 28 psi
    Chipset [X]|Injectors[X]|Turbo[X]|RS2 Manifold[X]|Bosch 3-BAR MAP[X]
    lol good luck bud
    ...: Enclo537 :...
    Good luck!
    2.09 for plugs?? what kinda plugs are u using?
    NGK G Power Platinum plugs, at FAP99.com
    actually, they're 2.32 a piece
