you should be fine rolling them if you don't drop over 2.5" in the rear... i have a higher offset but wider wheels (25.3mm=1") and running 235. 225 will fit for sure and 235 will put your tire about in the same place as mine becasue your lower offset and my wider rim pretty much cancel out (and i'm camber corrected as well which decreases fender clearance). overall your fitament should be fine.
