Thread: Popping and buzzing....WTF?
Showing results 1 to 5 of 5
    Is coming from my new front door kickers on my galant. It use to not do this, but after a few days with the kickers in the door, they don't sound good. The stock ones actualy sounded better but these are clearer than my stock ones. Anyways to the point, when the bass hits, the speakers make a pop sound, not even cranked up too much. Now after a month or two, its badd. I have to kick the door just to hear my front speakers. Sometimes it the front goes out, then i kick the door, it comes back buzzzing and popping, hit the door and its fine. Also, before the major buzzing started, i had to fade some of the front sound to the rear just so i could crank up the volume without having the front speakers pop and buzz
    any answers? thanks
    1999 North Star White V6 8G
    2003 Yamaha R6
    2008 Lancer Evolution X
    The Original FACTION from the BGR Days
    First Founder of TGC Florida 2002-2005
    Sounds like a wire is loose or something. Possible that the speaker leads are shorted or loose also.
    01-24-2005
    DFW/Stillwater
    2,752
    yeah thats what it sounds liek to me too
    keep in mind that aftermarket speakers are not going to make the bass your factory ones did. most are made to go along with subs
    Galant42C
    The reason why the speakers aren't hitting like factory is because the stock speakers are made for the response curve of the stock radio.
    The popping could be defective speakers, if the wire was rubbing somewhere the sound would cut in and out.
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    i say the connection is bad on the speaker or there is a loose wire somewhere
