Thread: What of this stuff would work with my 8G
Showing results 1 to 7 of 7
    Found what might be a great deal on a 2000-2005 3G Eclipse 4g64 Turbo Kit.... time is of the essence on getting this and I'm wondering if most of this stuff would be good. I have a 2002 4g64 ES A/T
    -turbo manifold 4g64 (3g eclipse)
    -7psi wastegate ( adjustable)
    -godspeed TYPE-L INTERCOOLER (20X9X2.75 CORE , OVERALL 28")
    -t3 hybrid turbo
    -blow off valve
    -oil return line and fitting
    -universal 2.5" aluminum piping with t clamps & silicone
    INLET - 2.36"
    OUTLET - 2
    BEARING TYPE - WET FLOAT BEARINGS
    OIL INLET - 1/8 NPT
    MAX PSI CAPACITY - 25PSI
    COMPRESSOR - .42 AR COMPRESSOR
    TURBINE - .48 AR TURBINE
    FLANGE TYPE - T3 FLANGE
    DOWN PIPE FLANGE TYPE - 4 BOLT
    Also I know that in would also need larger injectors, fuel pump and alterations to the ECU. Any suggestions in these deparements? Would going with an Apexi tunner be good enough for the ECU?
    08-06-2005
    Long beach/ guam
    1,585
    well if it comes from a 3rd gen eclipse, i don't see how it wouldn't work on your galant.. same engine..
    Proto
    http://cgi.ebay.com/ebaymotors/ws/eB...m=220237500923
    From the 2 tiny pics it looks like a normal eBay kit. I wouldn't buy it.
    Quote Originally Posted by Proto View Post
    The 'normal' ebay kit is not anything good I take it?
    04-10-2005
    NYC
    3,695
    the other pics show an ebay kit...if it is the first picture im sure its not a bad deal...try and find out whats up? see if they can send you more pics...
    Quote Originally Posted by airborneparainf82 View Post
    No. Nothing you will get from Ebay will be complete, and it will probably be mismatched and crappy anyways.
    1997 Volvo 850 T5
    kbeast
    make your own kit bro. Just look around on how to start
