Originally Posted by
RedGalant2k1
Sounds like a wiring issue up to the relay. If you hear it switch on your 02 and not your 99. But let me pull out the service manual...
EDIT:
Well, first off its two issues one with the cooling fans and one with the washer squirters, headlights, and parklights.
Based on what the service manual tells me for each of the problems (aside from the cooling fans) it hints at the following.
Windshield washer motor malfunction.
Column switch malfunction.
Front-ECU malfunction.
Damaged wire, connectors, or wire harness.
Based on your description and troubleshooting already done I'm lead to a wiring issue.
