Thread: ECUflash help
Showing results 1 to 12 of 12
    kbeast
    ECUflash help
    i cant seem to find the older version of ecuflash like 1.29A. where can i find them? And if you have it let me know because the version im using now does not work
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by kbeast View Post
    mtcavity has a copy of the version, don't know where my zip file is though :(
    PM him about it
    run1206's Rear Disc Tutorial
    kbeast
    another question.AFter reading from my ecu my idle is dipping again into 565 and sometimes stalling is this okay?i mean it resets idle after a day or so but do i need to flash after i read?
    08-15-2006
    Perth Amboy, NJ
    1,558
    did you flash it to a lower idle speed? did you adjust the MAF input signal? i don't understand why it would wanna stall after a read :?
    don't really need to reflash after a read cuz it should keep that ROM in the ECU cuz you didn't flash it.
    WarmAndSCSI
    We actually have archived versions of EcuFlash on Galant Forums
    http://www.galantforums.com/joomla/i...d=40&Itemid=59
    Hope that helps, I'll be keeping it up to date.
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by WarmAndSCSI View Post
    i didn't know about that, sweet!!!! :D
    heading over there to take a look.
    1.29a downloaded :)
    kbeast
    na it was just a read its being werid very werid. im going to try a read tonight
    08-15-2006
    Perth Amboy, NJ
    1,558
    k, just whatever you do... don't read while the engine is running. i did that last night and the car stalled :oops:
    kbeast
    drew dont fry your ecu. lol
    08-15-2006
    Perth Amboy, NJ
    1,558
    i know
    i adjusted the accel enrichment numbers around 2k-4k range and adjusted the deadtime injector voltages just a lil bit. it's 75 miles past that tune so everything should be good so far...
    kbeast
    i hate scaling so much
