Thread: Went nuts with paint
Showing results 1 to 7 of 7
    glolant02
    painted the fogs, headlights, foglight assembly and grill... let me know what you think...
    Attached Images Attached Images
    can you even see anything at night? that looks really dark.
    05-31-2005
    4,735
    too much
    that does look dark as hell
    Did you paint the lens or the entire inside housing of the headlights? Either way, I'm not sure about that. The best way would have been to paint the inside housing except the inner chrome part like in the pic below:
    I also smoked the amber corner lenses.
    I still have the smoked corner lenses. I pulled them out after my accident. lol.
    glolant02
    well the headlights are not on... its not as bad as you would think especially with my yellow HID's its actually quite bright... the fogs are wicked bright at night tho...
    glolant02
    i painted the outside of the headlights using two coats of clear smoke glass paint, then i hit it with two coats of clear glass paint... the fogs i used two coats of clear orange glass paint and two coats of the same clear glass paint.
