there are 2 green wires there. one green wire is slightly thicker than the other. the thicker one is for the turn signal
I'm attempting to tap in to the parking light in order to power some halo's in my headlights, but I'm not sure which wire is which on the parking light. Also, is there a way to tap in to this, so that it will just draw power and not flash when the turn signal comes on?
Here's a picture of the wiring plugged in to the parking light. Top from bottom wire colors are, green black green.
so u tap to the thin one which should just draw power and wont blink along with the turn signal
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
ok, so the thin green and then the black correct? judging by your sig, is this how you have yours wired spdracr?
Go to Autozone and get a test light for 6 bucks and it will solve all you problems now an din the future. You just poke the wire and that test light will tell you what you need.
no i have mine wired to a switch but yes the thin green is ur positive and the black is the ground
'95 Kawasaki ZX9R
