Probably something not properly connected...
when i put on my left blinker, after like 10 secs, it speeds up alot.....but once it speeds up the front blinker doesnt blink anymore and the back blinker blinks abnormally fast..what the hell is going on??
I dont need to post my mods, i know i got the hottest galant in tally, and thats all that matters to me! http://photos.yahoo.com/fsubk
check the contacts and make sure that they are good to go. maybe put in some bulb grease too to prevent corossion in the socket
If you've got aftermarket bulbs in your corners, chances are your contacts are depressed. Take the bulb out and use a jewler's screwdriver to pry up the contacts in the socket. Also make sure you don't have the bulb in backwards. That should take care of the problem.
Chip
Chip
(Paint Code: Porsche LC9Z)
Mine is jacked up too. Been that way for a long time. Tried adjusting the contacts and nothing works.
sounds more like a fault with the blinker module and I have no idea were you would find it
Under the dash at a guess
