Thread: struts mount
Showing results 1 to 2 of 2
    struts mount
    any body know where i can get this part at if i look on ebay what do i time in? i have search it and it has nothing so if any one a can help me out i need the part cause i have order the camber kit and need to do the alignment
    Got to www.mitsubishiparts.com and click on the OEM catalog. They have the rear mounts for $7.04 each and the front mounts for $34.09 each. Not sure what you are looking for, but if it's the fronts, be aware that there are upper spring seats as well as the mounts. The upper spring seats are $23.88 each.
