Thread: rubbing.....:(
Page 2 of 2 FirstFirst 12
Showing results 21 to 23 of 23
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by Danger DANJ View Post
    I was responding to the OP. He said his front tires were rubbing on plastic, so I'm assuming it's on the inside.
    You were correct, from what I understand he rubs on the plastic covers that protect his belts on pass side and the transmission cover on the driv.side. He says this happens when he turns at 30 miles/H. You have GR-2s with Teins springs not super rally car suspension , no offense. Thats your problem right there, soft suspension + turns at high speed=car weight shifts to that side, pushes the tire inward and there you have it. Slow down and problem solved.
    i've been slowing down and not doing it as much...but with o.k. suspension and wide tires it's kind of tempting to push the limit going into a few turns. anyway...a storm rolled in last night and the lightning was quite spectacular so i took some pics...hope you like.
    '03
    rockin' the DE
    Those pics are cool. Imagine if you had a DSLR camera.
