Thread: Rear Tubular Control Arms for 7g Tutorial
Showing results 1 to 20 of 21
    Tools:
    14mm socket and wrenches
    17mm socket and wrenches
    rachet
    hammer /optional/
    Well, after doing the swap of 8g lower control arms to 7g Galant, I've decided to swap the upper arms too. It's pretty easy, staight bolt on, no modifications swap and it took me around 1 hour, because I also did the energy bushings. The only advantage that I know of, is that the 8g tubular arms are lighter than the 7g stamped steel, and of course they look better and they are stronger!!!
    The picture below says it all, but if you do that please use lots of any penetrating stuff /wd 40, liquid wrench/, because I snaped on of the bolts and it was PITA to get it out.
    The 8g arms
    7g and 8g arms
    Installed:
    sweet.
    Nice, I need to pick up some 8g OEM suspension parts!
    07-20-2003
    Orlando, FL
    3,169
    I am curious of the weight difference between the 7g and 8g rear upper control arms
    how did you get those upper knuckle bushings in?i just did mine and i couldnt get them in ,in one peice.i had to cut them in half to get them in
    you got it right
    12-17-2002
    Sherman Oaks, California
    4,304
    what about the control arms, what advantages do the 8G ones have? stronger?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    tubular is stronger.
    ever compared the control arms from a 94 galant to a 98? or a 2g eclipse?
    the control arms on the 94 are just stamped steel with an open bottom.
    on the eclipses and the later 7g's there is a plate welded onto the bottom to box in the arm and reinforce it.
    Think about it, which would be easier to deflect? A 14" piece of "U" steel or a 14" piece of square steel.
    lets make it simpler. which woudl be easier to deflect? a flat 2dimensional 14" piece of steel, or a 14" piece or right angle steel( or L shaped steel)
    the flat length would bow if you put pressure on both ends. wheras the angle iron would not.
    tubular is much stronger than a piece of stamped steel.
    the 8g also has tubular lower control arms. that fit the 7g.
    RIGID FTW
    02-07-2007
    ORLANDO
    1,599
    suprisingly it hasn't been mentioned but aren't GTZ arms aluminum?
    Quote Originally Posted by 02redgalant View Post
    That would be sweet if its true
    do all the 8g's control arms fit on our 7g's i mean front and back, upper and lower
    no, just rear - upper and lower
    i think the rear struts and springs are the same also.
    briggs
    assuming the fronts will work also ?
    front what?
    NEWBIE
    10-31-2010
    Somewhere out there
    9
    This is great... I was actually wondering if there are any tubular control arms that could replace those on the 7g, they do look flimsy. If I remember right, there were even no backing plates in mine.
    08-18-2004
    Charlotte, NC
    1,029
    does the 2G upper rear control arm bushings fit the 8G upper rear?
    1994 GS FYI
    DSM/CSM Manuals
    Just wondering if I swap my rear arms what does it change in my rear sway bar options.
    Search is your friend.....
    MKO'S sway bar review
    Edit: I have the 18mm rear sway bar and 8g lower control arms from the pics.... i bought those from Mko a few years back.
