Thread: DIY $20 rear camber kit 7G/8g
Page 2 of 2 FirstFirst 12
Showing results 21 to 36 of 36
    Quote Originally Posted by EATsleepJDM View Post
    mko, which lowering springs did you get and how much inches lower is in the front?is the camber really noticeable?
    Eibach pro kit with AGX and lowers about 1.3 to 1.5 inches. I still havent had any problem with tire wear so far, but I havent driven long distance routes. When start driving back and forth to school, I will most def. get the camber kit.
    TGC Regular EATsleepJDM's Avatar
    05-17-2008
    Edison Park (NW Chicago), IL
    450
    the camber is barely noticeable?
    for this camber kit,where would i be able to buy the screws that are higher then 9.0 strength?i checked the hardware nothing higher.would there be any at an auto store?
    and about what dohcstuner said, where can i buy that spray for the screws as well?
    WANNA LOOK FRESH????
    GET SOME CLOTHES AT KARMALOOP.COM AND GET 20% ON FIRST PURCHASE WHEN USING REPCODE:KN21899
    siniGANG represent!
    Go to Autozone, I just got 10.9 bolts for my clutch. And if you mean where you can find antiseize grease - that would be any autoparts store.
    some ppl say they can see the camber angle of the wheel, but I cant see it. What I can see is that the tires are not worn out.
    05-17-2008
    450
    alright.thanks alot man.
    and thumbs up for the tutorial and your car.
    siniGANG represent!
    sorry for the cuestion but, when i need to do this?
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    When you lower your car, your rear camber specs go to hell, so to get it back withing factory specs you place a certain quantity of washers(depends on how low is your drop) and the longer bolts. If you get your camber as close to factory as possible your car won't eat the tires on the inside.
    4g64T 5spd
    Would anyone trust this to shave off -3.0 in the rear? It would need like almost an inch and half to to of washers and a really long bolt.
    05-03-2007
    Socal/Central Coast
    3,803
    what are you currently at? You shouldn't go all the way to 0 degrees camber.
    Its 2.9 in the rear. Why not 0?
    05-03-2009
    1,465
    No, dude the max camber I would correct with washers/shims is something around 1.25, also as beam says you don't need to go to 0, the shop I get my alignment at, told me that having around -1* is within spec but I trust tgc more so if anyone disagrees let me know.
    The kit to correct serious camber should look something like this.
    look for the Ingalls one
    http://www.importcarpartsplus.com/3g...ion.htm#Camber Kits
    4g64T 5spd
    I don't think I've heard anyone talk about the Progress camber kit - I just purchased it from importcarpartsplus and its listed under the Ingalls stuff. Should they be just as good?
    If it ain't broke, i'm still fixin' it.
    05-03-2009
    1,465
    Quote Originally Posted by RayDub View Post
    Yeah dude you should be good to go, and I talked about the ingalls because he said he wanted to correct -2+ degrees and ingalls has 2 different sets, I don't know how much camber you can correct with the progress one but I would assume around 1-1.25 degrees let us know when you install it.
    4g64T 5spd
    Thanks for that link, What do you think about the SPC one right under the ingalls stuff?
    For sure, thanks. I'm waiting for my order from them with my AGXs. I have Megan springs so the drop is coming soon.
    op can u re-up on the last two pics?
    What about front camber bolts?
    I guess i deleted them for PhotoBucket. It looks like it has washers under each bolt .
