Thread: need help with rear speakers
Showing results 1 to 15 of 15
    I just put it new rear 6x9 in the back of my car but I guess the magnet was too big and when I close my trunk the magnet gets hit by the two thin bars that hold the trunk up what can I do to make the 6x9 fit without getting hit by those bars and is there an easier way to take off the mat that covers the rear speakers?
    install a spacer to lift the rear speakers up.
    Quote Originally Posted by pinoyesv6 View Post
    thnx dude it worked out I had to mount it sideways instead of longways and its not under the mat anymore but its all good
    08-04-2004
    Westchester NY
    1,332
    hows it not under the rear decklid anymore? did you cut it? im confused
    NEWBIE SS8G's Avatar
    07-01-2008
    Surrounded By Corn Fields, Illinois
    10
    is there a way we could remove those bars and use the gas shocks I guess they are called to hold up the trunk lid so we don't have clearance issues with those bars?
    yah its been done.. but with cf trunks.. and it would work wiht the oem one with modification
    04 Maxima SL in Bronze with Black leather
    07-01-2008
    10
    Quote Originally Posted by mapid145 View Post
    what modifications would have to be done to it?
    01-19-2007
    Lyndhurst, NJ
    3,473
    You could take those torsion bars out and put your own shocks in there..
    07-01-2008
    10
    Quote Originally Posted by Jeffylou87 View Post
    that's what i said and mapid said there was some modification needed to use those, so i was just trying to figure out what
    01-19-2007
    Lyndhurst, NJ
    3,473
    You have to custom fab the work.. I don't think redline makes trunk lifts for stock trunks.. I know they do for CF ones..
    07-01-2008
    10
    like what has to be custom made. that is what i am trying to figure out dude.
    as in you have to drill holes on the trunk and where you want the supports to be. lol how do u know understand that
    07-01-2008
    10
    i'm not that stupid, i already knew about that, but you made it sound as if it was worse than that
    lol na man its really not that bad and any one can do it..just a drill and some stuff
    4,455
    you can remove the bars like others have said
    as far as a stock trunk, and CF trunk with the struts
    I have them on my CF trunk as do others and Qnz has them on his stock trunk
    you just need to order them for the trunk of an 02-07 lancer and specify that you need them for a stock trunk not a CF trunk. You can order from wesellcarparts the vendor on here or from redline direct
    and you need to get intouch with one of us that has installed them to get the measurements of where the rivets need to be put in
    Jason - - cofounder of TGCNY
    2001 Galant ES
