Thread: Transmission
Showing results 1 to 2 of 2
    Transmission
    I was driving to work today & looked behind me, saw a cloud of smoke coming from my car. Drove it a little to a parking lot & saw my tranny fluid leaking. As I pulled into the lot, the car wouldn't move & coasted to a stop. Towed it to my mechanic & said the front tranny pump is gone & probably need the tranny replaced.
    Put the car into drive at the shop, car caught a lower gear for a second, but wouldn't catch any gear since. Also here a ticking noise now.
    Any place I can find one cheap? I think I'm going car shopping.
    Thanks
    You can find one on car-part.com, but be aware that if you just swap one in, it might happen again. So if you get a used trans, I'd def. had the shop look it over. Mine went 2 months ago btw.
