Thread: LED washer nozzles question
Showing results 1 to 12 of 12
    asalem97
    Ok my girlfriend just bought me those led windshield washer nozzles. I hate these things I just think their straight up RICE, but I didnt' have the nerve to tell my girl cuz she likes em. Well I really dont wanna roll with these on my G but I gotta put em on. Basically could someone explain how to wire these to a toggle switch so I could just turn the lights on when Im with my girl and off at all other times. Thanks!
    12-17-2002
    Sherman Oaks, California
    4,304
    it's pretty easy...
    install a switch in the car - connect the ground to the...ground. then the switch will have 2 other leads. connect the power supply to one (12v) then the positive cables for the washer nozzle lights to the other lead. and obviously ground the neg. cables on the washer lights. the switch is usually labled, which lead should be "hot" and which lead should go to the source, but at worst case you can try either combo, u can't hurt anything. hope that helps.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    BEAST
    You could just hook them up to your blinkers
    paint them all the way to match ur car and then if she asks why u painted the whole thing, jsut tell her it don't work. at least u'll have high output washer nozzels.
    hey at least they look better than the stock ones i say.
    San Antonio, Tex-Mex
    1,413
    Why wire them?
    <-Check it out Maz
    My 7g
    queball
    Those damn things are just straight UGLY every time i see some moron driveing at night with them i just want to pull up next to them and tell how stupid they look..
    Break them. "Oh sorry hon, they don't seem to work"
    mitsubishigurl
    wiper blades
    <div class='quotetop'>QUOTE(BEAST)</div><div class='quotemain'>You could just hook them up to your blinkers</div>
    how would you go about wiring them to the toggle switch/blinker? I wanna get silver wiper blades to replace the black ones. My car is silver, would that look stupid?
    just return them and tell her theyre illegal, 'cause they are.
    Kain
    <div class='quotetop'>QUOTE(manybrews)</div><div class='quotemain'>just return them and tell her theyre illegal, 'cause they are.</div>
    Not true. Only the red or blue ones are illegal (at least in GA) I checked before installing mine. Though, I'm glad I put them on a switch because about two weeks after installing them I realized how stupid they looked when lit. They do look better than the ugly black stock pieces though.
    Re: wiper blades
    <div class='quotetop'>QUOTE(mitsubishigurl)</div><div class='quotemain'><div class='quotetop'>QUOTE(BEAST)</div><div class='quotemain'>You could just hook them up to your blinkers</div>
    how would you go about wiring them to the toggle switch/blinker? I wanna get silver wiper blades to replace the black ones. My car is silver, would that look stupid?</div>
    you can hook them up to the blinker so everytime you use blinker it i will blink...........
    AkA K h O p A r I.
    I Am back BitcheZzZ
