Thread: Gas gauge problem
Showing results 1 to 7 of 7
    Gas gauge problem
    hey guys i have a problem, i bought some ac gauges from ebay and had it installed. after they installed it i check it, everything seems to work fine, expept for my gas gauge. the gauge was down to E lower than E.( i had a half tank of gas before they installed it). so he told me to put some gas in it. so i did. the gauge went all the way to half tank. so i thought how the hell can this happen? my options were
    1: someone drained my gas
    2: there is still something wrong
    everything was working fine i was able to drive for a week with it. and now im almost at E and my gas warning light still wont light. usually by the time it reaches the second to the last bar my gas light turns on but now im still driving and my needle is already at E but still no gas light.
    what do you guys think is wrong with my gauge? i put a full tank of gas but the needle stops at the fourth line below Full.
    any info will be appreciated thanks in advance!:D
    i say fill the tank till the pump cuts off cause it is full then take your guage panel apart and then adjust the gas gauge to full
    Mods:
    your gas needle is not calibrated. he must have messed them up when he put them in.
    i knew something was wrong when he started moving it up n down just to prove to me it works. because evrytime he moved it up the gas would go down where it belongs. and i saw a post here before that you should never touch your needles or else its gonna get messed up. what should i have them do?
    04-10-2005
    NYC
    3,695
    unfortunately you just have to keep playing with it until you get it right...everytime you fill up your car move the needle to full, dont push too hard on it though, it should be about halfway on that pin it sits on
    damn now my temp gauge is acting weird. it takes a very long time before it even reacts. its just on C.
    damn i fixed it! finally.
