Thread: minor problems.. Rattling in the rear? Mb trunk
Showing results 1 to 13 of 13
    09-20-2004
    Queens, New York
    602
    I've been having minor problems wit the G. For the past couple of months there has been this annoying rattling noise coming from the trunk are. It only rattles when I hit a bump /rocky road. I thought it was my spare tire cuz it doesn't completely fasten down so it has room to wiggle. So I ended up taking the spare out, I also fastened the back seat down but the rattling is still occurring... Where could the rattling be coming from? It sound like it might be my shocks... Possibly? I have brand new agx's that ned to go on. Should I replace the whole mount?
    11-13-2007
    -OKC-
    3,970
    It sounds like your shocks are shot. When was the last time you replaced them??
    09-20-2004
    Queens, New York
    602
    I have never replaced the rear shocks just the fronts
    11-13-2007
    -OKC-
    3,970
    I always replace mine, front and rear at the same time. Well then do that and the noise will go away.
    09-20-2004
    Queens, New York
    602
    Should I replace the mount also?
    11-13-2007
    -OKC-
    3,970
    If it needs it, yes.
    01-19-2007
    Lyndhurst, NJ
    3,473
    That's the most annoying sound IMO..
    09-20-2004
    Queens, New York
    602
    How can I tell if it's bad (the mount) should I get them at the dealer?
    11-13-2007
    -OKC-
    3,970
    Well in the rear you don't have to replace entire assembly, just the rubber garment in the middle, there's one on top and one on the bottom held together by a metal shaft. This is something you can do. If you need a "how to " let me know and I'll help you out.
    EDIT:
    The shock mounts are like 8 bucks each so it's best to buy them instead of just the rubber pieces. Also replace the spring insulator if it's bad.
    You may want to have the sway bar checked, mine rattled in the rear over rough roads and bumps, took it to the shop and one side was bad. Bought the sway bar repair kit from NAPA and now the G is quite again. Just another possiblity.
    09-20-2004
    Queens, New York
    602
    What does the spring insulator look like?
    11-13-2007
    -OKC-
    3,970
    You will need to replace Number (SPRING INSULATOR )11 & Number ( SHOCK MOUNT )12.
    09-20-2004
    Queens, New York
    602
    Thanks so much for ur help!
