Thread: Alty Whine noise
Showing results 1 to 8 of 8
    TGC Regular
    09-20-2004
    Queens, New York
    602
    Alty Whine noise
    Ok So i got my timing belt replaced a little OVER a year ago. Ever since i got it replaced my alty SQUEALS like a mother ALMOST every time i star the car. Honestly, at this point I am getting really f'ed up with it!! I have tightened the alty belt a couple of times and the squeals goes away for a little bit but it keeps coming back. I cant tighten my alty belt any more, its is at its max.
    At this point what are my options? When i did the timing belt I replaced all my other belts so the alty belt is just a yaer old. Could it be my alty? But how? It literally started as soon as I got my timing belt replaced.
    nah bro, you just need to tighten it.
    Experienced TGC Member fliegendaffe's Avatar
    01-10-2008
    Oceanside/Camp Pendleton, CA
    1,848
    Quote Originally Posted by GOOSEY2099 View Post
    Quote Originally Posted by Cheekz185 View Post
    doesn't look like he can do that goosey
    11-13-2007
    -OKC-
    3,970
    Alternator belt and timing belt are two different belts dude. Just because you replaced you timing belt a year ago, doesn't mean they replaced the belt also. You can try some belt dressing, you spray it on it. Try to get it little tighter or just buy a new one, they are not very expensive and easy to replace.
    TGC Regular
    09-20-2004
    Queens, New York
    602
    Quote Originally Posted by RAZ_76 View Post
    When I replaced my timing belt, i repleaced the alty belt, and serpentine belt. And it only started happening as soon sa i changed everything. Im prolly just going to buy a new belt.
    now let me ask you something when you tightened it did you just turn one long bolt or did you first loosen the side bolt? I had this issue for years and never knew about the side bolt.
    I had the same problem after getting a new alternator belt. I bought a new battery and the alternator checked out okay, but the belt still squealed.
    Took it to a different mechanic, he looked at it for five seconds, tightened the belt a little bit more and the squealing went away.
    Now six months later it's starting to squeal again, so I guess I'll have to go get it re-tightened.
    TGC Regular
    09-20-2004
    Queens, New York
    602
    side bolt? Never saw that bolt... Where is it?
