they are easy...you will need some kind of adhesive on the backs of them to make them flat so the needles will not stick. i used superglue, but you shouldnt use superglue, it ruins the stock ones. I would try hot glue, rubber cement, or some strong, non thick double sided tape.
as for wiring, splice the power wire into the power wire for the dimmer. that way they will turn on when you turn on your lights. and for the ground....its just a normal ground.
thats about it, they are easy, just make sure when you are putting on the gauges, not to bump around the needles a whole lot, especially the gas needle
