Thread: Cleaning time/Seatbelt problem
Showing results 1 to 6 of 6
    What can I do to clean the seatbelts of my car? They are filthy dirty... How do I clean the side doors, the cloth part??
    How do I fix the seatbelt from the driver and passanger.. they just stay loose with out going back up to its orignal spot. Basically rewind itself.
    Thanks.
    Racers Against Street Racing
    the cloth.. u can use carpet cleaner and just scrub with a brush like a tooth brush.. the seatbeal u can just wipe with a terrycloth thats been sprayed with a cleaner.. i think a simple windex would work fine
    04 Maxima SL in Bronze with Black leather
    Thank u...
    to fix a seatbelt that wont retract very well...what could I do about that?
    I had tried fixing it using wd-40 but I think I just made it worst than it was before.
    Should I just get a bew mechanism or something??
    03-12-2007
    Dallas TEXAS
    2,041
    Quote Originally Posted by ruben71 View Post
    Thank u...
    you should buy a "new" one or its junk yard time plz use threadlock
    on the new one
    05-02-2008
    Hacienda Heights, CA
    3,014
    well just last week i took off my door panels and scrubed them with laundry detergent and water. it worth the work trust me
    Thanks
    Thanks buddies..
