Thread: Mitsubishi Lancer Sportback X Crossover to be revealed in 2010
Showing results 1 to 5 of 5
    Mitsubishi looks like its exploring all options of four-wheel drive Lancers. The new Lancer Sportback will also get a crossover version starting 2010, at least according to Japanese sources. The crossover will be sold worldwide and might look like the computer rendering pictured above.
    Likely to be called Lancer Sportback X, it will feature a slightly raised suspension for better ground clearance and a protective body cladding combined with new alloy wheels and a different front grille. To back up the new off-road looks, the Sportback X will also get the full-time 4WD system shared with the Ralliart and EVO X versions of the Lancer. Under the hood may be the 109hp 1.5-liter or 143hp 1.8-liter engines from the normal Lancer Sportback, or if we’re lucky, the Sportback X will get the 240hp turbocharged 2.0-liter engine from the Lancer Ralliart.
    2009 Mitsubishi Lancer Sportback
    http://www.topspeed.com/cars/car-new...0-ar61554.html
    I just don't like the colour~:(
    You are here entirely tooo much!! IVORY_G's Avatar
    07-12-2007
    SoCal
    4,632
    Looks like a cross btw a Lancer and an Outlader to me...
    JDM Zenki Conversion
    Lazy hands make for poverty, but diligent hands bring wealth. (Proverbs 10:4 NIV)
    Experienced TGC Member Galante's Avatar
    05-01-2008
    Manitoba
    1,589
    I like how it looks.. Hope they'll use an upgraded VR-4 engine on it..
    Tuned 2013 Evolution X GSR PB
    what's with mitsubishi and its 4 x 4 ride heights?
    Experienced TGC Member dwjp90's Avatar
    04-13-2008
    west chicago, il
    1,150
    ^x2
