Thread: Galante's 8g Build
Page 1 of 28 1234511 ... LastLast
Showing results 1 to 20 of 559
    05-01-2008
    Manitoba
    1,589
    Galante's 8g Build
    Before I start I would like to thank Trig for supplying my JDM parts (more to come) and Raz_76 for answering a lot of my preliminary questions before I decided to go on this conversion and advices on how things should be done and most specially TGC Tutorials.
    Last Saturday was when I started to dismantle my car's front... And trimmed the radiator support and stuff to make the jdm head fit (not perfect yet). Some pics below
    However, after fitting the head on the passenger side. I have some issues with the AC lines
    I will try to push the A/C line carefully in to make way for the H7 bulb and socket.
    I will also try to push the left head further in to reduced the gap w/ the grille.
    Tuned 2013 Evolution X GSR PB
    05-01-2008
    Manitoba
    1,589
    I will be able to get more jdm stuff this week.. Hope it comes in before the weekend.. So I can start to cut the crash bar..
    09-25-2006
    Central, Cali
    1,145
    looking good thumbs up
    03 I4
    Good progress. I just pushed my A/C lines back a little, and it fit fine.
    05-01-2008
    Manitoba
    1,589
    Quote Originally Posted by polishmafia View Post
    Thanks. I just wonder how many of the grille clips you were abe to use?
    if u line it up correctly u should be able to get 5 of them to clip, depending on the year of ur car will depend if the 6th (bottom middle) clip will clip in, if not, just cut it off
    Umm off the top of my head, I think 4 or 5. All of them were clipped into the headlights.
    05-01-2008
    Manitoba
    1,589
    I'm only able to use 2 clips and those are the middle ones since I cut the head's grille mounting tabs thin so I can push it further in and I used a longer bolt going to the radiator hole to secure it.
    u could have did that and saved the mounting tabs....only other option would be to zip tie it
    11-13-2007
    -OKC-
    3,970
    Others have helped me and the only way to return the favor is to help someone else. Glad I could help bud and Pm me when you have any other issues. Take lots of pictures.
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    Pay it forward...................LOL
    05-01-2008
    Manitoba
    1,589
    I still have the 9007 HID kit from my stock usdm headlight.. Have anyone tried to modify this to fit on the JDM heads for low beam?
    Quote Originally Posted by Galante View Post
    won't work. just buy new H7 HID capsules (bulbs) that have the same connectors as your (old ballasts) and use your old ballasts.
    05-01-2008
    Manitoba
    1,589
    I re-aligned the heads today.. and removed the gap from the right head light and grille..
    05-01-2008
    Manitoba
    1,589
    Thanks.
    hey can u possibly take the grill off and take a pic of how u cut the bracket on the headlight and the rad support, i have a good idea but i would like to see it in person
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    we gunna be twins when your done :D
    05-01-2008
    Manitoba
    1,589
    No problem I'll take a pic of that later after work..
    05-01-2008
    Manitoba
    1,589
    Quote Originally Posted by dknight3 View Post
    you bet bro.. :D
    05-01-2008
    Manitoba
    1,589
    I ordered a set of H7 HID bulbs 6000k for the heads..
