Thread: Galante's 8g Build
Page 25 of 28 FirstFirst ... 152122232425262728 LastLast
Showing results 481 to 500 of 559
  1. #481
    l'm sorry man...as for the clutch line bracket bolts, are you talking about the one underneath the battery that holds the hard line from the master to the soft line? if you are... i took 2 bolts from the battery tray... one that mounts the tray to the bracket, and then one from the bracket it self lol....
  2. #482
    05-03-2007
    Socal/Central Coast
    3,803
    that sucks man. Hopefully you receive those flywheel bolts soon. I found that dealers receive those little bolts and non-special parts very quickly. As for the clutch line bolts, you could probably still throw the 5-speed in there first without them, or do as galantman03 says and take bolts frmo somewhere else. They're pretty generic Mitsubishi bolts
  3. #483
    05-01-2008
    Manitoba
    1,589
    Quote Originally Posted by galantman03 View Post
    Thanks guys! Or I could probably get them at any hardware store. I just really need those flywheel bolts very badly.. I don't want to remove the auto trans while waiting for them and keep the engine hanging.
    Tuned 2013 Evolution X GSR PB
  4. #484
    Here's a thought.... hardware stores have grade ten bolts, take your old flywheel bolts from the auto flex plate, compare the thickness from the flex plate two the fly wheel, take a measurement, and go look for machine thread bolts in grade ten, that match the length you need... I have the fridanza flywheel, it came bolts that were 6mm too long, so I cut em, and it works great.... look around at hardware stores, I'm pretty sure they'll have something, if not check out a speciality faster store. Hope that helps
  5. #485
    get it from the dealer. The flywheel bolts have to be hardened steel.
    Jigz-TGCIL Sosick Motorsports
  6. #486
    05-01-2008
    Manitoba
    1,589
    I will definitely get the bolts for the flywheel from the dealer.. The other misc. bolts I can get from a local auto store..
    I got the shifter cables bracket today.. I got it bolted to the trans! I still need the universal connector for the reverse lights. Thanks for the props Jigz!
  7. #487
    no prob man, how close are you to completion?
  8. #488
    05-01-2008
    Manitoba
    1,589
    I still have to install the trans and shifter cables this weekend.
  9. #489
    05-01-2008
    Manitoba
    1,589
    I can't install the trans over this weekend. I don't have the 3g flywheel bolts yet.
  10. #490
    05-01-2008
    Manitoba
    1,589
    I'm almost done w/ the swap.. I have not taken any pics yet. I just need to run the shifter cables.
  11. #491
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    OOOO Im so excited, cant wait to see how everything turnes out man, goodluck
  12. #492
    05-01-2008
    Manitoba
    1,589
    Now I can say I'm officially 5-Speed! Got everything hooked up today. Here are some pics. I would like to thank the ff people for their support Stewi, 4G63Lover (Jigz), Beam514, stvn_mj, Goosey, run1206 and all others i forgot to mention who helped answer all my questions to make this swap possible.
    It's a different car now. I only have to wire the speedo and reverse solenoid. Also I have not properly installed the shift boot yet I just throw it in there.
  13. #493
    Congrats! Welcome to the 5-speed club!
  14. #494
    10-18-2007
    Glen Burnie, MD
    1,314
    Woohoo good job man!
  15. #495
    08-04-2003
    NY
    4,344
    Congrats man, your gonna love it
    99' Galant ES
    4G64/63T
    AEM EMS
  16. #496
    05-01-2008
    Manitoba
    1,589
    Thanks guys! Oohhh! I'm really enjoying it! My tires screech on 1st gear! Clutch is stiff though, is that normal?
  17. #497
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by Galante View Post
    Yes it's normal, it will break in. Good job on all the mods dude, specially this one.
  18. #498
    12-02-2008
    1,263
    Dude, awesome job on the swap. Hope you enjoy your new mod
  19. #499
    05-01-2008
    Manitoba
    1,589
    Thanks Ray! I got to use it everyday to break in.
    I'm loving it bro. Thanks.
  20. #500
    TGC Regular stvn_mj's Avatar
    07-30-2008
    Avondale, Arizona
    961
    congrats man i am so glad you got it done. Your car deserved it.
