Thread: Rust on Camshaft Lobes
Showing results 1 to 5 of 5
    05-24-2005
    Greensboro, NC
    494
    Heres my problem some of the lobes on the intake side of the head have quite a bit of surface rust on them. Can someone request a good cleaning agents that I should or should I just replace them. This is a N/A 4G63 head.
    08-04-2003
    NY
    4,344
    I would replace them, a good used set should be fairly cheap. There is really no right way to clean off rust that bad, if it was just a little bit of surface rust, you use a scotchbrite pad (steel wool) and your done, but I wouldnt put those back in my motor.
    99' Galant ES
    4G64/63T
    AEM EMS
    05-24-2005
    Greensboro, NC
    494
    Thanks, I was just hoping that I could save them.
    05-24-2005
    Greensboro, NC
    494
    Are the camshaft from a 1G and 2G the same?
    05-24-2005
    Greensboro, NC
    494
    Nevermind, I searched.
