Thread: Greddy's build thread!! Better late than never!
Page 51 of 53 FirstFirst ... 4147484950515253 LastLast
Showing results 1,001 to 1,020 of 1056
  1. #1001
    I've had an oil cooler installed since the first day the car was turbocharged. I'm running the evo 8 oil filter housing so I used the OEM evo 8 oil cooler and ducted it to the passenger side fog light opening. Also the housing has a built in thermostat so you don't over cool your oil on cold days.
    Car just doesn't heat soak as badly, it was about 90 out that day and it was just more consistent throughout a full session.
  2. #1002
    Ohh nice I didn't notice you had one installed already. Good to hear about the IC, I plan to use the ETS intercooler from the 2g eclipse since that's the spec I am using now.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  3. #1003
    Retuned the car after an EGR delete, not a lot of peak gain but plenty of midrange gains, red line is after the tune
    Clutch pedal brscketsnapped coming of the dyno
  4. #1004
    Best stock block 4g64 and still plowing. At the same time though fuck push type clutches. There isn't a piece of the hydraulic system I haven't seen it break yet.
  5. #1005
    You don't have the reinforcement bracket installed?
    Sent from my DROID RAZR using Tapatalk
  6. #1006
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Holy shit that graph just got nastier
    4g64T 5spd
  7. #1007
    Look at the boost plot. It slowly climbed up to max psi to control wheelspin/save the drivetrain? Now boost is a flatline. Looks like someone tuned the boost plot and that is why there is a huge hp and tq increase in that area specifically
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  8. #1008
    It slowly climbed because that's what the car would do with the MBC turned down all the way, crept like a mofo. Since I ported the wastegate the boost no longer crept. We deleted the egr at the same the time. I've played with suspension settings and tire pressures to eliminate wheelspin and I decided to make as much midrange as possible without changing peak boost. We actually made 360wtq but decided to tune it down a bit for stock block "longevity"
    As for the clutch I've decided to go with a DSM twin disk with a hydraulic TOB in the future, and the transmission is going to get built to TREs stage 2 rebuild in preparation for 400wtq in the not so distant future.
    Car made 280/290 on 15psi.
  9. #1009
    Nice numbers..oh and kinda off topic but i just saw this looking at meet vids on youtube.. @ 4:06 http://m.youtube.com/watch?v=1huvksUP0Mw
  10. #1010
    Yep, that's my miata.
  11. #1011
    Gonna build a motor to go with that trans?
  12. #1012
    if I actually shoot for 400wtq I might, the goal is more to have a bulletproof trans to hold the current setup, Im quite happy to throw another stock block in if this one blows. If I do build a motor it will stay SOHC and just be rods and pistons with an AMS moroso pan, I currently have a custom baffled stock evo pan but I like the extra oil capacity of the moroso pan. I also have a spare head laying around so I might have it gone through and ported and maybe do valvesprings and retainers and rev it to 7000. Again, all potential future outcomes but at this point the car is great the way it is and I have no complaints with the exception of the annual clutch fork replacement job.
  13. #1013
    There ought to be a shop near you who could shot peen and heat treat that fork. It blows me away that all that clutch hardware breaks with just a 2200 pound plate.
    Valvesprings should be on the top of your list if you end up doing anything with the head. DO NOT get RPW if you reach that point though. I've got a far better option for you. Porting will get you a very long way as well even with the stock cam.
    I'm surprised and impressed that your motor has held together this long. You've been pushing way past the supposed limit all the "gurus" of the past laid out years ago. Goes to show it's a proper setup.
  14. #1014
    Its currently a 2600 pressure plate, I bought a 2200 to put in next time but I don't know of it will hold the power.
  15. #1015
    TGC Regular boosting90's Avatar
    05-14-2014
    Central Florida
    426
    ok first things first....... awesome way to raise a galant. awesome number and build on tht motor. car look awesome ever since u started doing ur touches.
    CAR
    MOTOR
    TURBO SETUP
    SUSPENSION
    EVERYTHING IS OPTIMAL AND SICK....... LONG WAY AND THE CAR HAVE PAID YOU BACK WITH ITS OUTCOME.
    FUUUUCKKKK TOOK ME LIKE A WEEK TO GO THRU UR BUILT(IM NEW HERE LMAO) WELL WORTH IT ^^^BEEN SAID.
    NOW QUESTIONS LOL
    DID YOU EVER FIGURE OUT THT MYSTERY LIP YOU FOUND?
    YOU STILL ROCKING THE 99-00 BUMPER???
    WILL LIKE TO KNOW DETAILS ON UR ENGINE MANAGEMENT SETUP??? (U DELETE EMISSIONS? 2STEP?)
    SORRY IM NOT NEW TO CARS OR BUILDING THEM. JUST A LITTLE STUCK WITH MITSU COMPUTERS, HARNESS. (YES I HAVE SPEND HRS ON SEARCH/READING/INVESTIGATING.... ALL I SEE IS ALOT OF DIFFERENT OPINIONS) GLAD TO HEAR FROM PPL WHO HAS SWEAT AND PUT IN WORK TO GET THERE. LIKE UR SELF AND ALSO GALANTMAN03(I THINK HIS NAME) 4G63TLOVER ETC... READ ALL OF THEIR BUILD.
    SORRY IF I ANNOYED YOU JUST INTRIGUED.
    THANKS (DONT WORRY THEM BOYS ARE GONNA GET QUESTIONED) LOL
  16. #1016
    It's a Lancer Oz rally lip. Stock 99_00 bumper. Evo 8 ecu. I have no emissions related parts left on the car. No check engine lights.
  17. #1017
    05-14-2014
    Central Florida
    426
    So u can turn off emissions on the ecu?
    Evo8 ecu comes ported for tunning?
    Whats a bbk turbo?
  18. #1018
    05-14-2014
    Central Florida
    426
    Thanks for the replies.
  19. #1019
    yes you can turn the emissions of with the ecu, the ecu is tuned through the OBD2 port, a BBK turbo is a stock frame evo turbo make by CBRD.
    new temporary transmission is in along with an ACT 2100 PP and 6 puck sprung disk, combo should be good for 420wtq, Ive put about 100 miles on it so far and the pedal is much more daily driver friendly. Cant wait to get my old trans back from TRE after it gets upgraded with their stage 2 rebuild, also looking into doing a transmission cooler and mounting it in the driver's side foglight hole.
  20. #1020
    05-14-2014
    Central Florida
    426
    Nice good. Thx alot for response. Good info.
    Good to hear u back on the road.
    Whats stage 2 consist on trans build?
