Ive searched all day and cant find straight answers...this is on a 95. What is the reccomended timing setting? Do you ground the brown connector when you set the BISS screw as well? Do you ground the brown connector when you set the TPS? what is the reccomended voltage for the TPS and which wire do I probe? These are easy questions that the search wont pull answers up on.
