how u gonna do the speed sensor? 7g is electronic, 1g manual. there was a guy who put a 1g tranny on 7g, and he had tutorial in 7g section. hell know better about the axles
Well I'm about to buy a 1g gearbox from teamrip.
I know that the 1g gearbox will bolt right up on a 4g64 block, well for my car is no problem, cause i've put the rear bracket on the engine block, so no prob with the rear support.
The only question I have is will the axles of a 7g galant go in a 1g gearbox.
I also want to buy some fidanza fwd axles, but for wich car do I've to buy it?for a 1g or a 2g?
MKO is right read that tutorial it will answer most of your questions
https://www.thegalantcenter.org/showthread.php?t=30376
Says 7g axles fit in a 1g gear box. So if 7g axles fit into a 1g gear box, 2g axles fit into a 1g gearbox and also into our 7g hubs. So I would order 2g axles. 1g axles would fit into the 1g trans obviously, but I dont know if they would match up to the 7g hub(they may, I dont know).
Seth is that you in you avatar? And what are you /he saying?
hes saying," IM GONNA EAT YOU! NUM NUM NUM NUM NUM NUM NUM NUM!!!"
141,000 miles.
6 dents.
Yellowed, cloudy headlights.
spraypaint on the door panels.
