Thread: Baby G ~ 2000 Galant ES I4
Page 11 of 70 FirstFirst ... 7891011121314152161 ... LastLast
Showing results 201 to 220 of 1389
  1. #201
    got the flywheel, clutch, and trans in. Shimmed the pivot ball as well.
    getting the trans in with the thicker aftermarket flywheel was a pain, if it didn't hit the PP it hit the subframe. But with a little patience GmoEm2 and I got it in. when I heard the disc go into the input shaft I was more than extatic.
    Going back to work on it Monday because it's my moms birthday party tomorrow and I dont work on cars on sunday.
    Jigz-TGCIL Sosick Motorsports
  2. #202
    10-18-2007
    Glen Burnie, MD
    1,314
    Hmm I only have a few things left to get till I start my swap. Can you point out anything im missing?
    So far I have...
    Trans
    Clutch
    Flywheel
    Pressure Plate
    Trans Mount
    Master Cylinder
    shifter assy.
    All thats left is...
    Slave cyl
    clutch line
    brake/clutch pedal
    shifter cables
  3. #203
    off the top of my head it looks like you need a TOB and the TOB return clip.
    if you have an OEM 3G Eclipse flywheel (Has to be from mitsubishi) you're going to need a second flywheel washer. if you have an aftermarket flywheel (2G, aftermarket 3G, or REMAN 3g) you are going to need longer bolts. I used the 2G flywheel bolts and threw the two washers out.
  4. #204
    10-18-2007
    Glen Burnie, MD
    1,314
    Yup I do have the TOB threw on the one that came with the exedy, and the return clip Im assuming is the little clip the holds the TOB onto the input shaft? I do have an OEM flywheel, where the hell can I find this washer? lol I need CAPS so I can find the part number. :p
  5. #205
    the return clip clips onto the fork.
    and you can get the washer from the dealer for 5bucks.
  6. #206
    10-18-2007
    Glen Burnie, MD
    1,314
    Ok ill have to go pick one up sometime soon.
    On a side note... someone banged up my pass side fender today :'(
  7. #207
    Got most of evrything in. Just need to put the suspension back together and the axles in to put it on the ground. Then, all I need to do is bleed the clutch, pour some gear lube in it, and adjust the clutch.
    OMG look at the space!!
  8. #208
    02-07-2007
    ORLANDO
    1,599
    mannn thats nice all that space...no more fat pos auto
  9. #209
    10-18-2007
    Glen Burnie, MD
    1,314
    If I were you I would pick up some grade 8 hardened steel bolts instead of those grade5 bolts. They might break :p
  10. #210
    jigz along the side wall there should be a clip to slip down the ss line for the clutch!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  11. #211
    Quote Originally Posted by WhiteGalant View Post
    which bolts? the one on the mount? lol. I Have all the other three studs in so it should be okay.
    Quote Originally Posted by Ivory8g View Post
    Thank bro!! I can't wait to drive it!
  12. #212
    np! dude it will feel like a new car when you take it out for the first time! remember no beating up the clutch until it is broken in!
  13. #213
    Actually, the clutch already has 3k on it but I'm still going to baby it for the first 100 miles or so. I really can't wait!
  14. #214
    I would as well every car is different letting it bed in for 100 miles should be good
  15. #215
    There would be a break in anyways because you should have resurfaced the flywheel. Unless you are using the same clutch.
  16. #216
    I got a brand new flywheel so I will definitely break it in.
  17. #217
    and by breaking it in you mean beating the shit out of it right?
    1996 galant s
  18. #218
    I have to pull the trans out again early tomorrow. I might've shimmed the pivot ball a washer or two too much.
  19. #219
    08-04-2003
    NY
    4,344
    jigz make sure you loctite the pivot ball threads after you put it back.
    99' Galant ES
    4G64/63T
    AEM EMS
  20. #220
    Update?
