Thread: Baby G ~ 2000 Galant ES I4
Page 53 of 70 FirstFirst ... 34349505152535455565763 ... LastLast
Showing results 1,041 to 1,060 of 1389
  1. #1041
    UPDATE:
    Going to be out of town all week so I figure I put some time in. Pulled the subframe so I can properly prep the engine bay and remove the evap emissions tube, and remove the old fuel lines and convert the steering rack to a "manual rack". Once I got the whole subframe out I took the suspension off of it aside from the sway bar and the lower control arms. Going to pull the tank when I get back and will decide on if I am going to keep the stock tank and Walbro or beef it up. I know for sure I want to run a -8 or -10 feed and a -8 return.
    Anyways heres some pics for some good measure.
    While its out I figured I'd clean it up too once the snow lets up.
    The engine bay is ready for prep.
    Leaving her like this for a week.
    The motor is still at the shop, hopefully I get her back when I get back.
    Jigz-TGCIL Sosick Motorsports
  2. #1042
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    what color are you gonna spray it and why are you going with a manual rack?
  3. #1043
    Quote Originally Posted by xd_01 View Post
    As far as color, Im going to play with a couple patterns and color combos.
    I dont have power steering, I had it looped for a while now and I want to get rid of the loop so I am going to modify the rack so that its a true manual steering rack.
  4. #1044
    BOSS!!
  5. #1045
    Jigz, if you do want to truly make the rack manual i would suggest dissasebling it and cutting some of the inner metal seals out in order to make a properly depowered rack.
    Great work my dude, keep it up.
  6. #1046
    Quote Originally Posted by greddy View Post
    You hit it on the head. That's exactly what I am doing.
    Thanks man!
  7. #1047
  8. #1048
    Little bit of progress.
    Used some "rust performer" on the engine bay and firewall. Snaded it all down and grinded down all the surface rust I could get to and sprayed that shit on liberally. Im pretty impressed the metal looks awesome.
    This was an "Instagram Exclusive" photo. But My Galant brothers need to have it as well. Still gotta finish snading and smoothing out the drivers apron. Should be able to finish that up today.
    Also got the motor back to the house. Machined, assembled, and with a new oil pump!!! Just waiting on some ARP lube before I can permanently mate them. Heads got the HKS cams, Fidanza cam gears, and Kelford valve springs installed. Also used ARP mains and ARP bolts for the rods came with the Manleys.
    Safe to say I am excited and I am making sure I am working on the car atleast an hour a day.
    Well, thats it for now. Tune in for more.
  9. #1049
    08-26-2007
    1,148
    Keeping the balance shafts?
  10. #1050
    U beat me to it.
    Also can u get a shot from the other side of the engine?? I wanna see how close that compressor housing is to the starter.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  11. #1051
    Yes I am keeping them. I replace the belts as soon as the intervals are up so its not something I worry about.
    U beat me to it.
    I will try and get the manifold and turbo back on and get a pic for you.
  12. #1052
    It's not about the intervals though. I replaced my belts when I bought the car. 40k miles later guess what happened?? Balance shaft belt snapped and tangled up my timing belt and caused that to snap. Avoid such a failure on a built block. It's just so much safer. That's my opinion.
    '95 Kawasaki ZX9R
  13. #1053
    Ugh that motor looks gorgeous already. meh balance shafts are a letter of opinion. Built evo motors have kept em just fine. I left mine in. Decided not to leave it. Never had a problem ever
    Sent from my HTC6500LVW using Tapatalk
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  14. #1054
    thanks guys!!
    BTW, finally got to paint the engine bay this weekend. It's a different blue than the exterior but I like it!
    Going to finish up the motor, then the rack then the subframe and front suspension can go back in.
  15. #1055
    Sexy!
  16. #1056
    08-26-2007
    1,148
    paint looks good
  17. #1057
    You'll have to make a trip to MN this summer.
  18. #1058
    Much better than black! Looks good Jigz.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  19. #1059
    Motor and bay are lookn clean
  20. #1060
    Got most of the motor back together. Cleaning up the bolts so I can polish them. Also waiting on an OFH gasket, and a someone to sand blast the water pipe.
    Clearance looks promising. Mind you, I am on a half radiator so the forward clearance is no issue.
    Picture of the whole thing.
    Also ordered the Quaiffe, diff bearing, and the speedo gear.
    Safe to say, we are moving along.
