Thread: 00Galantguy's Progress Report
Showing results 41 to 60 of 96
  1. #41
    05-31-2005
    4,735
    nice
  2. #42
  3. #43
    Im weary about the leather/vinyl paint stuff since I used the duplicolor stuff maybe that was my problem. But I have another can so im gonna throw on a couple more coats.
  4. #44
    Met up with pete today and yesterday. Was a good time.
  5. #45
    WTF pete? can't park within the lines and ish?
  6. #46
    Quote Originally Posted by 00galantguy View Post
    Sexy cars! :D very nice
  7. #47
    Lucky bitches. I need to get back up there again sometime soon. The cars are looking good as always.
  8. #48
    The lines were crooked. We both parked like that... and ish. :D
  9. #49
    what kind of interior paint did you use? cause I want to paint mine black too...
  10. #50
    duplicolor vinyl paint
  11. #51
    It would work just fine, its designed to be able to flex and be stressed.
    On the site it said it is meant to "enhance and repair faded carpet, not a drastic color change" does that mean it won't work for turning my gray back seat black? And it said it is NOT a dye... anyone had experience with the stuff?
  12. #52
    Quote Originally Posted by HungarianHunter View Post
    I sprayed two armrests with it. One I wrapped in CF, the other is just painted black. No it isn't a dye which would be a better, though more expensive way to alter the color. It should be more than adequate for minor refinishing and light to moderate use of the seats or door panels.
  13. #53
    So basically it's better for non-frequently touched places? Cuz I always have people in the back seat. Damn. Any back seats fit our G's?
  14. #54
    the dye should never crack. but the paint if you use ur back seat a lot will. in fact i dont even use it that much at all and look waht happened to mine
  15. #55
    to everyone who has asked this is what i used on my back seat
  16. #56
    Oh snap, I thought that was just how the seats were when you put them in. Yea, in that case I'd dye it also.
  17. #57
    yea so i basically get to scrub off the paint and redo them with dye... learn from me and do it right the first time :)
  18. #58
    Quote Originally Posted by KaziKai View Post
    my bad... I used krylon fusion for plastic. First sanded them lightly... then primed. ... then painted.
  19. #59
    Is there a spray-on dye? Or how would I go about dyeing the seat black?
  20. #60
    SEM Color Coat is a spray on dye. As I have said before you will need 2-3 Cans. You first clean the surface very well.. I used soapy water and a brillo pad. Then lightly rough up the leather with a high grit sand paper. Now spray on your dye.
