Thread: HOW DO THEY INSTALL LIP KITS???
Showing results 1 to 5 of 5
    ozkrow
    well i was wondering how they installed lip kits...like how they get it on the bumper ect. what materials do they use...u know...thanx for the info
    imgntht
    Best place for you to look is Wings West website. Search on a '98 Acura CL and then follow the links to the install info. They show a picture and list the materials needed, plus step by step install instructions. Hope this helps. :thumbsup:
    Tiller
    don't buy it unless it bolts on... otherwise, you have to have it molded on, and if the lip cracks you're fucked, and will not be able to just "take it off"...
    they might use a double sided tape though too, but that's just ghetto IMO...
    it all depends on the material. i mean with urethane lips its most likely it just sticks on with double sided tape and screwed on at the ends, with other lips you jsut bolt on and with others you get it molded on. it all depends if the lip was made for your exact car
    slowgalant
    just rivet it
