Thread: 6G Galant info needed.
Showing results 1 to 2 of 2
    EVILGSX
    I was woundering if any body has or know of a listing of compatable ECU's for the 6g galant. i have a 1990 GSX and i need to get a ECU for it. The number on mine is MD153303.
    i was woundering if any body knew of any compatable ECU's.
    the only compatable one is the exact same one. there are probably a dozen ECUs for that year alone, all for different options and trim levels (calafornia emmisions, automatic vs manual, air conditioning, SOHC vs DOHC, etc.etc.)
