Check the passenger side switch. It mightve gone bad. If you can still roll the window up and down from the driver side, then the regulator and motor should be fine. But if you cant do it from the passenger side, it sounds more like the switch or wiring is bad. Check to see if the switch is properly connected to the wiring harness. Make sure all the wires are intact.
