Thread: How to fit a 7G A/T shifter on an 8G
Showing results 1 to 16 of 16
    So this morning I went to the junkyard and saw the 7g automatic shifter and thought ,"hmm, that looks a lot better than mine!"
    I ended up buying it for around $3
    After taking off my 8g oem shifter (place it in L for maneuvering)
    it looked like this VVVVVV
    Now shave the top little triangle with a dremel
    VVVVV
    To make the top of the inner tubing fit the white plastic, you know need to shave the edges:
    VVVVV
    Test fit to make sure its somewhat snug, some freeplay is fine
    VVVVV
    Now I simply used a flashlight and aligned the bottom hole of the 7g shifter to the top hole of the 8g shifter column,
    Honestly it is a little loose(it only has one screw holding it!) but im sure ill eventually take it off eventually and drill a hole lower and shave more off the top of the white plastic piece we shave earlier.
    Final product;
    Now i keep my fingers crossed and keep checking the junkyard for the oem silver trim pieces or paint them myself.
    5-speed 6G72 w/ bolt-ons [sold]
    '93 Nissan 240sx vert
    Except for the OD function, good that it fits :)
    Experienced TGC Member Galante's Avatar
    05-01-2008
    Manitoba
    1,589
    Looks good. Nice pick up.
    Tuned 2013 Evolution X GSR PB
    Yeah i know but its whatever, now my interior looks more appealing to me now. Maybe i could wire it up to some tyte neons yo haha JK. My friend said i should write NO2 on it instead hahaha
    maybe you can hook up your fogs to the O/D switch :)
    nice work :)
    that does look a hell of alot better might pick one up and try it.......wonder what other stock shifters would work??
    Banned
    06-07-2008
    Orlando FLAWDA
    533
    that same proces can work with Any shift knob really. I think all Stock shifters look *yuk*. ya might as well use an aftermarket one while you're at it. I did that same exact thing last year with a Pilot, and then a Greddy shift knob.
    last pic i took w/ pilot..
    yea i have mine like that now its jst really loose.
    TGC Regular starh4x's Avatar
    11-30-2008
    New Zealand. HTOWN
    527
    did you ever end up hooking anything to that switch? that would be gangs if u did.
    Senior Moderator mrjaydeeone's Avatar
    07-31-2002
    Woodbridge NJ/Staten Island NY
    4,455
    I used to the OD button on my levoc shifter to control my interior neons
    Jason - - cofounder of TGCNY
    click banner to enter the NY Chapter
    2001 Galant ES
    2004 Jeep Grand Cherokee Special Edition
    11-30-2008
    New Zealand. HTOWN
    527
    sweet!!!
    Gbaby2089
    wow my 97 avenger es had same shifter!
    01-19-2007
    Lyndhurst, NJ
    3,473
    Am I the only one that likes my stock shifter?
    A+ for the work though..
    ^yeah jeff, I'm pretty sure you are
  15. #15
    thestig
    looks good but i made it so that i could use a long aftermarker manual shift nob. i did the same procedure though. great minds think alike. lol. i hated that big bulky piece of crap. in order to shift it i just push down on the whole nob. looks great though. good job
  16. #16
    Looks 10x better than the stock shifter but I'm a bit worried about how secure it truly is.
Tags for this Thread
