Thread: dohc clearance issue
Page 2 of 6 FirstFirst 123456 LastLast
Showing results 21 to 40 of 119
    08-04-2003
    NY
    4,344
    Quote Originally Posted by GOOSEY2099 View Post
    BTW 4g64 can only be bored .20 over not more. 4g63 can go .80 over i believe. You said "right now i have a 4g64 block with cosworth sleeves", show me a pic as i call a Flap!
    the only time I have seen them sleeved is when the block needed to be bored more than .040 over. They end up boring the block wayy over and then press in ductile iron sleeves. It will pretty much look like a closed deck honda block. I would never invest in this unless it was extremely difficult to find another used 4G64 block.
    99' Galant ES
    4G64/63T
    AEM EMS
    ill try to find a pic of the block apart its together now
    o yea i have come across another problem the oem cam sensor on the hyundai does not fit over the evo cams what could be a fix for this
    08-04-2003
    NY
    4,344
    You mean the reluctor right? not the sensor? The reluctor is the cylinder with the two tabs on it that goes into the end of the exhaust cam. I think you have to run the one from an EVO if im not mistaken. I have only used the EVO head never a kia or hyundai head. The most info on this is over on club3g a bunch of guys there have done this.
    99' Galant ES
    4G64/63T
    AEM EMS
    07-16-2006
    Cocoa, Florida
    791
    yeah you have to use the evo cylinder what wait that cylinder are you trying to use!? a galant one?, lol i know for a fact hes has the galant one on there its the only one that does not fit
    no its a cam sensor it gous on the exhaust cam but the cams are set up for an evo so the bolt on the end is too big so it doesnt slide over it
    08-04-2003
    NY
    4,344
    No. The piece that physically bolts onto the exhaust cam is called a reluctor, sometimes called a timing cylinder or the like. The cam sensor is the electronic sensor that goes into that external housing which bolts to the head. Take a picture of what your talking about and post it up.
    99' Galant ES
    4G64/63T
    AEM EMS
    o yea can i use arp head studs off an evo 8 if im using the hyundai dohc? thanks
    cam reluctor... get an evo one.
    07-16-2006
    Cocoa, Florida
    791
    i don't think he searched enough, and yes you can, i just put some on mine
    what manifold are you using right now?
    intake or exhaust? intake magnus "RACE" manifold and for exhaust jus some ebay one
    are you gonna clear the starter with this exhaust manifold ??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    it hopefully will since its off an aeclipse its the pwr steering thats going to b a problem w/e ill make a bracket and put it somwhere else
    yea, it will clear the starter. My manifold looks just like his except its flanged for a 38mm WG instead of 44.
    You might want to ceramic coat that manifold if youre going to use it. My ebay manifold got really hot before I wrapped it.
    TGC Regular bmore303's Avatar
    03-11-2007
    Baltimore, MD
    773
    If you don't mind me asking, what exactly are your goals with this build?
    RIP
    1995 7G 4G64 / 63T DOHC Turbo
    Part Out Coming Soon
    In search of 2G 3000GT VR4
    Daily driving
    Dat '08 Cobalt Coupe
    07-16-2006
    Cocoa, Florida
    791
    is that your engine can i see it with the valve cover off?
  19. #39
    thats an old pic i had saved on my comp its all bolted up now
  20. #40
    updates lol also a question the evo adj cam gears will work with the hyundai head?
