Thread: EVO ECU will work in a DSM 4g63!
Showing results 1 to 20 of 24
    interesting info:
    http://www.dsmtuners.com/forums/tuni...-2g-works.html
    apparently, the evo ecu will work with the DSM 4g63's, allowing you to use Ecuflash and evoscan. This will open doors for you guys with a 4g63 swap. (i'll either use this for my starion 4g63 swap or DSMlink)
    Cali: Sig 3/28/2011
    Yeah i saw that on dsmtuners earlier today.
    But i'm already rocking ds-map so it would definatly be a step back for me.
    08-18-2004
    Charlotte, NC
    1,029
    I knew it will work...somebody finally DONE IT!
    BTW, the Evo 1-3 ecu plug and play with the 94-95.
    1994 GS FYI
    DSM/CSM Manuals
    tru that, but we're talking about a evo VIII ecu....now im stuck trying to decide between DSMlink or Ecuflash...
    Cali: Sig 3/28/2011
    dsmlink is awful.
    its not load based tuning, and its remedial as hell.
    Plus..... with dsmlink, you really can't do much to fully tune your part throttle powerband.
    Does evoscan let you run native wideband?
    meaning your ecu is ACTUALLY USING wideband readings instead of narrowband... as opposed to just having the wideband going through the ecu for nothing more than logging(like dsmlink)
    no u cannot -- evo scan is just a logger not a tuning software -- - ecuflash is what tunes the evo ecu... U can only use narrowband for closed loop but with the evo ecu the transition is tunable and you can tune the part throttle if u need to ...
    some people have figured out how to use the jdm evo 9 map sensor to go speed density using the stock ecu though... Tuned and runs off of only the map sensor but they have not released the info yet..
    Kansas City, MO
    1,244
    Hmm this is great news. There is a shop very near by Modified by KC . The guy there has an Evo VIII last tune ran about 660 whp. that i've been waiting till i can get a 95 eprom ecu before i have him tune it. So i'll have to look into the Evo ecu now.
    Quote Originally Posted by Blue Ice View Post
    i got an eprom if you really want it.
    already ordered a extension harness to modify and an evo ecu. i'll post up what cables needed to be jumped when i'm done.
    Cali: Sig 3/28/2011
    dsmlink is awful.
    DSMLink actually does allow for active narrow and wideband. You just need a programmable wideband like the LM-1. I am effectively simulating narrowband with my LM-1. You dont even need dsmlink for that feature. You can use the LM-1 alone.
    I'm pretty sure what he's asking is if the ECU will accept the wideband signal INSTEAD of having to read a simulated narrowband signal.
    222whp/250wtq
    08-18-2004
    Charlotte, NC
    1,029
    They recently updated the thread on which wires to swap, etc.
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    Quick question: Since the Evo 7+ ecu works on the 2G, will the 01+ Eclipse ecu work for us NA guys?
    1994 GS FYI
    DSM/CSM Manuals
    it it should...you can flash the 3g ecu with an evo rom and it works the same.
    Cali: Sig 3/28/2011
    Just an update, my 7g is up and running with an Evo 8 ecu.
    Quote Originally Posted by tom04841 View Post
    you should update this thread with the wiring changes.
    Cali: Sig 3/28/2011
    Well, It is basically the 2g ecu swap, once that is done, you follow the 2g to evo 8 ecu swap in the first post of the dsmtuners post.
    The one thing I will note is that the car idles alot better than it did with the 2g ecu. I haven't taken it for a drive yet because the car is gutted. The back seat is gone and am in the process of fiberglassing my enclosure for 4 12's. I can't stand the smell...lol. That, plus the fact that the axles are out cuz I am starting the 5sp swap.
    johnd
    so will the evo ecu only work for the full 4g63 swap or can you do it with the 4g64 4g63 head swap
    Quote Originally Posted by johnd View Post
    You dont have to do the full 4g63 swap, or even the 4g63 head swap. I am still on the stock 4g64 longblock. I am turbo'd, running coil-on-plug, and have no distributor....i swapped that out with a cam sensor, cam cylinder, and housing (support) from a 99+ 4g64 as seen in this thread https://www.thegalantcenter.org/showthread.php?t=28029
    johnd
    so to run the evo ecu is it pretty much the same swap as the 1g or 2g ecu and if so what would that do for the performance aspect
