I have removed my interior panel about 30-40 times and no broken pin. All you have to do is undo the screw and pull so the little tabs unclip at the bottom. And then make sure you unplug the window switch. At least thats how it works for the 8g im not 100% if its the same but I would think its gotta be similar
