Thread: about offset for 8G
Showing results 1 to 16 of 16
    about offset for 8G
    i am looking for 18" rims for my 8G GTZ and those have many different offset
    i know +45and up is ok. +38 will rubbing.
    QA is how about +40 (225-40/18 tires)??
    +38 will only rub if you dont roll the fenders I believe. 00GalantGuy is running an 18x8.5 wheels with +38 offset. pm him about it
    Jigz-TGCIL Sosick Motorsports
    Stock height you will be fine, if you are lowered with +38mm wheels you *may* need to roll the fenders. It largely depends on how low you lower the car, if at all.
    01-24-2005
    DFW/Stillwater
    2,752
    im on 37 no rubbing, but me fenders re slightly folded in the back
    05-31-2005
    4,735
    yes. 38mm will rub. fold your fenders. it will be worth it.
    Quote Originally Posted by I-chih View Post
    depends on width. width and offset TOGETHER determine clearance. we can't really calculate for you if you don't give us both measurements. w/ 225/40r18 tires i am assuming 7"-8" wheels +40? that should fit fine unless your drop deep, then you will have to roll rear fenders.
    10-24-2003
    1,432
    It really depends on your suspension set up. I was on a +12 set with compound rubber, and that would rub a little in the rear. Now with the JIC coilovers and about 1 3/4" drop in the front and 1 1/4" out back it doesn't rub at all.
    The wheels in the picture are a +35 17 x 8 rear 17 x 8.5 in front. Also on a 245 so there is alot of tire there to go with it.
    www.gooichimotorsports.com
    will 18 inc wheel rub with tiens and eibach on v6?
    What he said. I run 18x 8.5 enkeis. I run progress springs and gr2 struts. The only time I ever rub is over large bumps... and thats only after I got an alignment and the camber was off. Before the alignment it never rubbed
    Quote Originally Posted by 01nygalant View Post
    width? offset? tire size?
    dang! this whole time i thought my evo IXs were 45 offset...but they're actually 38...WHAT DO I DO?! i dont wanna waste my moneys on rolling my fenders. 8(
    Experienced TGC Member SleekGTZ's Avatar
    05-09-2005
    Washington state
    1,065
    Mine doesn't rub. Although I'll still definitely roll my fenders (or dremel) after all this snow crap.
    I have 18x7.5 with +40mm offset. Tires are 225/40/18. Lowered on Tein S-Tech, KYB-GR2.
    Quote Originally Posted by kalvinsaid View Post
    just go get the right size tire. 225/45r17 (or even 215/45r17 if you're paranoid).
    i shalllllllllll
    (and merry christmas everyone.)
    Rolling your fenders is free if you use a bat and a heat gun.
    never. you wouldnt give your gf charcoal when she asked for makeup would you? same thang...HAHAHH (no offense to the people who used a bat and a heatgun)
