Thread: Loud exhaust
Showing results 1 to 10 of 10
    Loud exhaust
    So the exhaust is loud and the reason is obvious. My question is can I weld a new flex pipe in or do I have to replace the whole pipe.
    2.0 Sohc 1990
    just go to an exhaust shop and get it fixed bro. should be a cheap cut and weld fix. Shit, if it was me I'd just put a new exhaust system in it.
    Jigz-TGCIL Sosick Motorsports
    The one shop I took it to quoted me 150 without seeing it then insisted the whole pipe be replaced and quoted 394 just for the pipe... I told them where they could stick it...
    Would any of this affect performance and or gas mileage?
    fuck that, whered you go?
    do you have a caseys in WI?
    A place that used to be good to us but now theyre under new ownership. They are called bms.
    1996 galant s
    07-20-2003
    Orlando, FL
    3,169
    Quote Originally Posted by 00galantguy View Post
    Yes...you aren't getting any backpressure and the motor will be sluggish and will effect MPG.
    You can buy just a new flex section and any good exhaust shop can weld it.
    Sounds like a good time to replace the entire exhaust system!
    NEWBIE
    06-28-2005
    Appleton, WI was Madison..
    15
    Quote Originally Posted by 4-G-rim View Post
    I hope this got fixed before the snow fell.
    Ive welded in new flex sections on a couple of my galants.
    Last one I bought I got from Carquest.
    -Shawn
    <a href='http://imageshack.us' target='_blank'></a>
    '92 Galant LS
    '92 Galant VR-4
    '92 Galant GSR
    '93 Galant S (DOHC swapped DD)
