Originally Posted by
RAZ_76
I say just drain it from that plug I showed you, let it drain until it stops, then put the screw back in and the next day remove it and let it drain some more, you should drain at least 3 quarts or more. Then put the screw back and add about 4 quarts back, start the car and get it really warm, place your foot on the brake and go thru the gears but don't move the car, just go from P to R to N to D and so on and stay in each gear f a few seconds. After you do that a few times, put it in park and check the level. Don't overfill it.
