Thread: Headlight restoration
Showing results 1 to 20 of 25
    07-20-2003
    Orlando, FL
    3,169
    Well after years I did the initial headlight lens restore I just felt that the old Blue magic plastic polish wasn't getting the results I truly wanted. A few months ago I bought the Mequiars PlastX and there was a noticable improvement in the lens clarity and was happy with it. The only gripe I had is that I had to reapply the stuff every month or so before the lens clarity was degrading.
    One my friends thats a detailer for a dealer recommended this 3M stuff as he talks highly of it for headlight lens restoration, scratch removal, and true UV sealer. Its 3M Shine restorer with carnuba wax and for a small bottle its pricey at $10.
    I applied the Mequiars PlastX first and high speed buffed it then applied the 3M stuff and my headlights look like they are brand spanking new. :shock: The pics I took don't really do the justice on how the lens look...they are emaculate!
    Along with my "cloudy headlights removal" tutorial I wrote...I strongly recommend using these 2 products together for the final touches and you should be very satisfied with the final results.
    I will see how long the lens clarity lasts and post updates. I am hoping the clarity will last longer than just using the Meguiars PlastX, as I hope the 3M UV sealant will prolong the lens clarity.
    Nice, they look great, I'll vouch for this product, I've used i on both my cars.
    my foglights are pretty bad, you think i could hit them with some 600 grit then 1200 grit, then polish with these?
    ive been wondering about this for a while i dont want to ruin my 300 dollar fog lights lol.
    Quote Originally Posted by dknight3 View Post
    There is a headlight restoration system that has 300 grit, 600 grit, and 1200 grit, then a fine polishing grit, and buffing compound. I did a set of headlights on my wifes car, and a set of 7G headlights, works great.
    But the plastic polish above works great by itself also.
    Mother's Mag & Aluminum polish works great aswell. Along with their plastic polish. I usually just use the M&A polish with a buffer leaving a nice shine.
    12-27-2005
    Charleston SC
    1,520
    I did the sanding method over 2 years ago and they still look brand new.
    lor_tek
    I've also used the 3M and that stuff works. I have not used the Meguiar, but from what I see, that stuff is great. I might have to try it out.
    04-25-2007
    727
    wow that looks great, I got to get on some of that the next time in Orlando... Hey G_Rim Check ur PM...
    Nice bro!
    Mikey
    97 Galant ES-T 64/63
    97 Eclipse Spyder GS-T
    Good how-to
    Popular Mechanics had a really good how-to on wet sanding a few months ago.
    http://www.popularmechanics.com/auto...o/4252611.html
    2000 Mitsubishi Galant (totalled by semi, RIP)
    2000 Mitsubishi Galant - Bought off Craigslist, received organ donation from last one:
    - Engine/5spd trans/interior/suspension/brakes/etc. all moved from old car
    - 5spd | Outlander IM | StopTech BBK | Defi VSD-X HUD
    you can do it whit a 2500 sandpaper and polish, easy
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    ISMASG90
    Watch these guys, you can try their methods for cleaning the headlights. http://www.youtube.com/watch?v=Cy_WF5Iei_I
    12-27-2005
    Charleston SC
    1,520
    the 3m kit is by far the easiest and most effective method. takes about 30 minutes and costs 18 bucks at walley world.
    quick question, what if you dont have a polishing tool? so far ive been using Turtle wax's head restoration kit, and it does a great job although Im doing it by hand, and I just press really hard and buff as much as possible.
    I sanded mine yesterday using the Turtle wax kit and let me tell you, they look brand new. I think the most important thing about restoring your headlights is the sanding. It took me 4 applications to finally get rid of the yellow that had clouded just one of my headlights (Go figure) but they look brand new. So sand, sand, sand with 4 different grits
    Once you're satisfied and they look crystal clear, you apply a sealant (Included in kit) so they wont turn yellow again.
    I Look back at this, I can never really tell with 7G heads if it works. To me the lens on them looks like it was designed cloudy. Maybe someone with 8gb heads that are cloudy can try this and post some before and afters.
    No one of my headlights is crystal clear like see the bulbs clear but the insides get cloudy so you have to do both sides
    PITA
    Me I'm a lil of both
    They only get cloudy because they are made out of plastic that goes thru heat cycles and gets lots of UV damage. I remember getting two pretty much brand new looking heads from the yard and 6 months later they will start getting cloudy.
    No such thing with the glass ones.
    One day I will have said glass ones
    I guess they just don't make them like they used to.
