Thread: Help with my setup - wiring diagram included
Showing results 1 to 20 of 25
    TGC Regular starh4x's Avatar
    11-30-2008
    New Zealand. HTOWN
    527
    this is my current setup. or well i think it is how it is wired. does it look right?
    i was wondering if i get a decent amp and sub how much worse will it be to use the high level speaker level input rather than RCA? i want to keep my stock head unit so no shitheads break in..
    Proto's Minion Jasmine's Avatar
    01-24-2007
    New Zealand
    355
    As I told ya, upgrade your head unit first and foremost. You don't need to go fancy fancy, just something good enough to run subs/amps decently.
    Or play with your amp settings or setup, but I personally doubt it'd make a difference.
    Maybe someone else can offer some insight.
    And again I can't make sense of your diagram ;)
    09-25-2006
    Central, Cali
    1,145
    ill tell u this u didnt wire it right im surprised its even working from ur diagram
    03 I4
    09-25-2006
    Central, Cali
    1,145
    another tip find out ur RMS out put from ur amp find out ur RMS on ur subs
    excample my setup 1 800 RMS sub 1 600 RMS Amp
    03 I4
    05-02-2008
    Hacienda Heights, CA
    3,014
    yeah, your gonna have to get another head unit if you really want it to sound nice. jack one off a honda haha
    11-30-2008
    New Zealand. HTOWN
    527
    Quote Originally Posted by jimmy_o2 View Post
    its not wired like that. thats just how i thought it was wired? i didnt install it professionals did. i dont know how the wiring really is but i would like to find out.
    300watt amp 700 watt sub?
    Quote Originally Posted by E_Emerson88 View Post
    hahahahahahaha:smt104:smt104 probably not lol :smt104:smt104
    can someone please tell me the difference between high level inputs on the amp and rca inputs for the amp? if high inputs are letting me down i will have to buy an aftermarket and on top of that an alarm.
    how can we help u unless you show a real diagram.. not what you think, there is no reason your amp would be grounded to the head unit, the ground should be as short as possible. Just buy a cheap pioneer head unit, no one will want to steal it and it will tie your system together..
    http://www.walmart.com/catalog/produ...uct_id=8224432
    The above link does the job and won't cause anyone to break in imo
    Mods:
    01-24-2007
    New Zealand
    355
    Yeah, Pioneer definitely do the job, and in the long run an alarm will be a good idea anyways, especially insurance wise, as it will decrease your premiums. But yeah, get an older Pioneer. As I said, it doesn't need to be flash.
    I tell you now, if it was wired by proffessionals, it should be ok. I don't think at all your wiring is the problem.
    11-30-2008
    New Zealand. HTOWN
    527
    Quote Originally Posted by guynlidia2006 View Post
    Quote Originally Posted by Jasmine View Post
    you guys are bastards im going to be soo poor soon. :smt110
    and wtf ofcourse my amp woudlnt be grounded to my head unit. thats just showing the speaker level output from my heady to the amp.
    01-24-2007
    New Zealand
    355
    Hey hey now, just offering suggestions you don't need to take it :P
    Someone grounded my amp to my battery once...freaking bastard. Never used him again.
    11-30-2008
    New Zealand. HTOWN
    527
    rofl did u hurt him? :smt079
    09-25-2006
    Central, Cali
    1,145
    yep
    03 I4
    Quote Originally Posted by starh4x View Post
    dont ask for advice if you cant handle it
    Mods:
    11-30-2008
    New Zealand. HTOWN
    527
    give good advice. no offense but obviously my amp would not be grounded to my headunit. i can understand though because the wiring diagram was bad. please look at this new one guynlidia.
    my main question is, what is the difference between high level input and RCA into an amplifiier. i ask this because the stock headunit has no RCA outputs and i would like to keep if possible to prevent break ins.
    Get yourself a hi/lo converter to keep your stock deck. Easy to install, but only downfall to this is not being able to control your lows from your head unit. Unless you have an amp with a control knob. Sound quality is okay but never the same if you had an aftermarket deck.
    11-30-2008
    New Zealand. HTOWN
    527
    Quote Originally Posted by Frankv View Post
    thanks. yeh im gonna have to think about it. thansk everyne
    09-25-2006
    Central, Cali
    1,145
    ur diagram is still wrong
    03 I4
    11-30-2008
    New Zealand. HTOWN
    527
    yeh well could you correct it pleasE? i was assuming it was wrong from the beggining.
    my sysetm sounds much better now anyways. my sub box was too small for the sub. i bought a kicker c12 and new box.
    09-25-2006
    Central, Cali
    1,145
    ok first pic is the correct way
    second pic what i would choose for ur setup what u see in the yellow box is an EQ curcle in red means do not connect it there in green would be where u connect them
    03 I4
    11-30-2008
    New Zealand. HTOWN
    527
    thanks !!!!! exactly what ive been looking for
